Mile calc question
Discussion in 'Gen 2 Prius Technical Discussion' started by tripp, Apr 23, 2007.
  1. tripp
    tripp Which it's a 'ybrid, ain't it?
    4,717
    79
    Denver, CO
    OK, here's my problem. My MFG got reset in the middle of a tank. I know what the MPG reading was and I noted the trip odo reading so I know how the tank breaks down....
    53.2 MPG/377.5 mi
    55.8 MPG/93.4 mi
    So how do I avg the two together to get the correct mileage for the entire tank?
  2. efusco
    efusco Moderator Emeritus
    19,891
    1,196
    Nixa, MO
    work it out backward for gallons used for each segment. Add together the total gallons used and divide the total miles by the number of total gallons.
    7.096 gallons + 1.674 = 8.77 gallons
    470.9 mi/ 8.77gal = 53.7mpg
  3. tripp
    4,717
    79
    Denver, CO
    What's that formula for calculating it with just distances and MPG? Someone brought it up once for showing why you shouldn't accelerate slowly (bad mpg over longer distance).
    That number looks about right. I was guessing something in the high 53's.
  4. MurryMc
    MurryMc New Member
    Try:
    Total MPG = ( Leg1 Miles + Leg2 Miles [... + LegN MGP * LegN Miles] ) /
    ( (Leg1 Miles / Leg1 MPG) + (Leg2 Miles / Leg2 MPG) [... + (LegN Miles / LegN MPG) ] )
  5. tripp
    4,717
    79
    Denver, CO
    That's the one... Evan did the same thing, of course. Thanks guys.
  6. qbee42
    qbee42 My other car is a boat
    18,058
    3,079
    Northern Michigan
    Hey tripp, you might want to loosen up that helmet a bit. :D
    Tom
  7. IsrAmeriPrius
    IsrAmeriPrius Progressive Member
    4,333
    Southern California
    My formula is a bit different.
    [segment 1 miles*MPG] + [segment 2 miles*MPG] / total miles = average tank MPG.
    [53.2 * 377.5] + [55.8 * 93.4] / 470.9 = 53.71
  8. vincent1449p
    vincent1449p Active Member
    894
    332
    Singapore
    <div class='quotetop'>QUOTE(IsrAmeriPrius @ Apr 24 2007, 06:29 AM) [snapback]428666[/snapback]</div>
    your formula is not correct. Please try the below e.g. and you will see the big difference:
    99 MPG/1 mi
    50 MPG/1 mi
    Using your formula:
    [1 * 99] + [1 * 50] / 2 = 74.5
    Using the correct formula:
    2 / ([1 / 99 ] + [1 / 50 ]) = 66.4
  9. Betelgeuse
    Betelgeuse Active Member
    1,460
    24
    New York, NY, USA
    It's not that there's some "magic" formula that you need to use to calculate this. Remember that MPG stands for "miles per gallon," or, in other words, miles/gallons (miles divided by gallons). That means, if you know the MPG and the miles, you just need to divide the miles by the MPG and you'll get the gallons used:
    a miles / x (miles/gallon) = z gallons
    Then, you just add up your total gallons, add up your total miles (which was known information) and divide the miles by the gallons. Bingo! Total MPG!
    (a miles + b miles) / ((a miles/ x mpg) + (b miles / y mpg)) = Total MPG
  10. IsrAmeriPrius
    4,333
    Southern California
    <div class='quotetop'>QUOTE(vincent1449p @ Apr 24 2007, 04:33 AM) [snapback]428916[/snapback]</div>
    Except that I got the exact same result that Dr. Fusco did when he first calculated the total number of gallons used and then proceeded to divide the total miles driven on that tank by the number of gallons.
  11. vincent1449p
    894
    332
    Singapore
    <div class='quotetop'>QUOTE(IsrAmeriPrius @ Apr 25 2007, 09:09 AM) [snapback]429426[/snapback]</div>
    Not exact but close. The reason it is close is because the miles (numerator) is large as compared to the gallons (denominator). Which is why I've chosen a small numerator for comparison.
    Another point to add is that your units of measurement are not consistent. We know miles divide by gallons is mpg but what is miles*mpg? m²pg?
  12. IsrAmeriPrius
    4,333
    Southern California
    <div class='quotetop'>QUOTE(vincent1449p @ Apr 24 2007, 11:43 PM) [snapback]429612[/snapback]</div>
    You win.
  13. alexstarfire
    alexstarfire New Member
    220
    Well, I'm no math newb, but the way IsrAmeriPrius did it is correct mathematically. The only reason it doesn't work is because it's distance.
    Or maybe I've just been to sleep deprived.
  14. Norm611
    Norm611 Junior Member
    45
    Western New York
  15. alexstarfire
    220
    I know, since I actually had to try both formulas to figure out why his didn't work properly. Like I said though, mathematically he's correct. Like if you took the gas out of the equation. He averaged the numbers properly, but since there is a hidden third factor it doesn't compute out properly.
    Either way he was wrong and you were right.
  16. daniel
    14,487
    1,519
    Spokane, WA
    Why do you care what your mpg was for a given tank? Are you correcting for odometer inaccuracy? If not, the figure is incorrect anyway. In any case, your lifetime average is much more significant than your mpg for each tankful.
    (This from someone who remembered to write down gallons pumped only about half the times I filled the tank, and finally quit record-keeping altogether. And my odometer is off by around 3% anyway, and in the end I don't really care what my exact mileage is, because this is a low-stress car and keeping track and worrying about getting one more mpg out of it is a high-stress activity.)
    (I really can't wait for my Xebra to come. That's going to be a really low-stress car, with no gasoline ever and no gas engine to worry about why it didn't shut off when I think it should have.)
  17. John in LB
    John in LB Life is good
    399
    27
    Orange County
    <div class='quotetop'>QUOTE(Alexstarfire @ Apr 26 2007, 02:21 PM) [snapback]430802[/snapback]</div>
    Sorry to interject - but this item is not up to judgment or opinion. This is math - and the equation was just wrong. The formula applied did not keep the units straight.
    There is only one way to do this calc: (Mile1 + Mile2) / (Mile1/mpg1 + Mile2/mpg2) = (M1+M2)/(G1+G2) = Total MPG.
  18. hill
    8,919
    <div class='quotetop'>QUOTE(daniel @ Apr 28 2007, 09:47 AM) [snapback]431636[/snapback]</div>
    daniel, you'd love the mpg estimator on our RX-400h hybrid. It WON'T do per/tank . . . only does lifetime. You can break the cycle by hitting reset, but other wise (like the everready battery bunny) it just keeps going and going and going. I prefer the Prius' per tank, as that way one can moniter the differences between tire pressure, # of passengers, temperature, etc, much easier.
  19. galaxee
    galaxee mostly benevolent
    9,810
    471
    MD
    leave it to the geeks at PC to post up 17 replies about a math equation :D
    (... i had to. :lol:)
  20. daniel
    14,487
    1,519
    Spokane, WA
    <div class='quotetop'>QUOTE(hill @ Apr 29 2007, 03:06 PM) [snapback]432200[/snapback]</div>
    No, I wouldn't. :rolleyes: It would tell me that my lifetime mpg is lower than I wish it was. With the Prius I can just mentally more-or-less average those tanks that I feel are worth including, and ignore those winter and short-trip tanks.
    OTOH, I'm counting the days until my Xebra comes and I can quit burning gas for in-town driving altogether. :)
