Mileage Decrease
Discussion in 'Prius v Fuel Economy' started by buckaroo, Oct 14, 2012.
  1. buckaroo
    buckaroo Junior Member
    64
    Austin TX
    Recently returned from trip from Austin Tx to Monroe LA. Gas mileage decreased from about 43.3 MPG to 38.5 MPG. A little annoyed by this but I guess I can attribute this to the increased weight in the vehicle. Still taking care in for other thing. Maintenance needed light came on & I assume it may be for a 15,000 mi checkup since it is nearing that mark.
  2. Phil 29 Palms CA
    119
    44
    Twentynine Palms, CA.
    To increase your mileage make sure your tire pressure is at 40 psi (front and rear). Drive with 'ECO Score' menu showing. Adjust the accelerator pedal as required to keep the EV Drive lamp ON as much as possible. View the YOU Tube vedio on Prius C driving tips. Note: Pluse and Glide.
    49,488
    could also be a lot of highway miles?
  4. skwcrj
    skwcrj Member
    278
    68
    Gig Harbor, WA
    A lot of highway miles driving at 75-80 mph?
