mileage didn't reset after gas fillup
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by fintonissimo, Aug 14, 2013.
  1. fintonissimo
    fintonissimo Member
    111
    Chicagoland
    Hi all, I have never had this happen, but when I filled up with gas today the mileage in the display didn't reset to back to zero after I turned the car back on and drove away. Is this indicative of a problem, or is it just a fluke? Has anybody else ever experienced this?
  2. xpcman
    xpcman Senior Member
    1,302
    295
    California - SF Bay area
    Don't you have to push a button to set it back to zero?
  3. boppo
    boppo Active Member
    799
    138
    Owego, NY
    Mine has a reset button.
  4. fintonissimo
    fintonissimo Member
    111
    Chicagoland
    This is a 2008 Prius, the mileage for each tank automatically resets back to zero after you fill the tank up and start the car without pushing the reset button. If you push the reset button, it also resets the avg. MPG, which I prefer not to do. Anyway, since the mileage didn't reset on its own this time, I'm wondering if something is wrong.
  5. vskid3
    vskid3 Active Member
    773
    228
    How much gas did you add? It might not have been enough for the car to realize that the tank is now full.
  6. fintonissimo
    fintonissimo Member
    111
    Chicagoland
    I was down to one pip, filled up with 9.6 gallons. So, I'm still wondering...
  7. KK6PD
    KK6PD _ . _ . / _ _ . _
    4,003
    944
    118
    Los Angeles Foothills
    Apparently not "Always".
    I make sure I manually hit Reset. I see it reset.
    It's like holding the Power button down just a little longer to make sure the car actually turns off!
    Safe, dependable, works every time!
  8. fintonissimo
    fintonissimo Member
    111
    Chicagoland
    You're missing my point, though. I don't care to reset it. I'm only concerned because it is supposed to reset on its own and it didn't this time. This is the first time in almost 100 K miles that the mileage didn't reset to 0 after filling up.
  9. uart
    uart Senior Member
    4,215
    1,201
    Australia
    Can anyone clarify which Gen2 year models do auto-reset the mileage which don't. Mine is a 2005 model and definitely auto-resets, but I was under the impression that 2006 or later models were manual reset so that you had the option of doing "lifetime" (or multitank) averages. I'm sure that several people here have told me this. Perhaps this behavior is an option that you can set somewhere?
  10. bisco
    49,693
    when i had my '08, sometimes it would reset automatically, and sometimes it wouldn't. and i always filled from around two pips. not sure why, but i doubt anything is wrong. i bet if you ask the dealer, they will be clueless as usual. i'm not even sure if there is anything in the manual about it.
  11. fintonissimo
    fintonissimo Member
    111
    Chicagoland
    Ok, now the plot thickens...after my first post on Aug. 14th, I drove the car for 500 miles and had one pip remaining. Therefore, Thursday night Aug. 22 I decided to get gas. MFD indicated my average mileage as 53.8 MPG over the past 2 tank fillups.
    I started to pump the gas but it shut off early, I had only put in about 4.5 gallons! I know it isn't a good idea to top off the tank, but I honestly didn't think it could be full; so I tried to put a little more in. I gave a couple more squeezes, and put in .4 gallons more. Assuming the gas pump might be malfunctioning, I moved to a different pump. I started the car up, and this time the mileage did reset automatically to 0. At the other pump, I gave only one squeeze, and it immediately shut off, not allowing me to put in any more gas. However, the gas gauge was indicating only 8 pips, not full!
    I then drove about 35 miles, and noticed the gas gauge had gone down to 7 pips. I found a gas station and this time I was able to fill the tank to the point that it registered as full. The mileage did reset again to 0. With the 3 fillups, I was only able to put in a total of 8.5 gallons into the tank...yet, when I started, I was down to one pip and had driven 500 miles. My past experience has been that when I'm down to one pip I can usually put about 10 gallons into the tank. Only in the winter does it shrink to the point that I can only put 8 gallons in.
    So, now I have some questions/concerns:
    1) Are the two issues related? (tank first not resetting to 0 and now having trouble filling it up all the way)
    2) Why did the gas pump shut off with the tank only registering 8 pips? You would think it would shut off only if it was registering as completely full.
    3) Wondering if this (problems with filling up the tank) is going to be a continual problem now, and if so, what to do about it.
    I'm well aware of the shrinking bladder syndrome with this car, but what stands out to me is odd is that the tank wasn't full, only at 8 pips, but I couldn't fill it up all the way until I drove it 35 miles and went down to 7 pips. Also, I would expect that after having driven about 500 miles that it would not be filled after only 8.5 gallons in the summertime.
    Thoughts/insights?
  12. fintonissimo
    fintonissimo Member
    111
    Chicagoland
    Nobody has any thoughts on this? Isn't it odd to not be able to fill up the tank when it is only indicating 8 pips?!
  13. Whiteyprius
    Whiteyprius Active Member
    389
    105
    North Carolina, USA
    I have a 2008 - with a mind of it's own! For now, i'd consider it a fluke and not worry. The gas gauge & auto reset can sometimes be a mystery - and over sensitive auto cutoff pumps can really confuse the poor thing!
    Q10 ? 2
  14. Jamesb93612
    Jamesb93612 Member
    133
    69
    Clovis, Ca
    I've only had one time where my '08 didn't reset automatically. I have however, had multiple times where the pump shuts off prematurely. I know it is not full. After driving 500 miles a week for the last 2 years, I have memorized which pumps work best along my route.
  15. wjtracy
    wjtracy Senior Member
    11,329
    3,593
    Northern VA (NoVA)
    I seem to recall some fuel gauge recalibration steps you may want to try.
    My 2006 needs manual reset...news to me some Gen2 did not need this.
    I have had a few strange fill-up events but if it goes back to normal I forget about it.
    PS- nice job on the 500 mile tank my record is 485 maybe you have better gasoline
  16. Britprius
    Britprius Senior Member
    5,194
    1,917
    Herefordshire England
    I have a UK 2008 (no bladder) this always rests the millage on that tank when I fill up. I usually run 5 tanks (3,000 miles) before resetting the average mpg and that roughly aligns with the four seasons allowing me to check millage variation with temperature.
    John (Britprius)
  17. Coolride17
    Coolride17 Junior Member
    55
    Mine does when it wants too.
