Mileage down by 10%
Discussion in 'Gen 3 Prius Fuel Economy' started by whovian10, Aug 11, 2016.
  1. whovian10
    whovian10 New Member
    New York
    I have a 2013 Prius 3 and the first 3 summers I had fuel economy of about 58 to 60 miles/gallon. This summer I am down to 52 - 55 miles/gallon. Any suggestions as to why?
    49,494
    welcome!
    how many miles on her?
    has your driving changed at all? tyres pressure? oil level?
    warmer weather/more a/c?
  3. whovian10
    New York
    115,000 miles
    I drive 120 miles round trip to work every day.
  4. Mendel Leisk
    38,728
    Wow, that's a punishing commute.
    In addition to bisco's items, you might check the Exhaust Gas Recirculation circuit. It's around your miles it can start to coke up. Quite reliably. There's a pipe between the EGR valve and intake manifold, just one piece of the circuit, but relatively easy to remove for inspection.
    #4 Mendel Leisk, Aug 11, 2016
  5. Lucifer
    Lucifer Senior Member
    1,014
    485
    Nh
    Time to do some maintenance to the running gear, the brakes may be sticky, the emergency brake cable may be sticky, the bearings may be a bit dry, the tires may be low (air), the 12v battery may be consuming gas (weak) even the interior cabin filter may be clogged, causing more ice intervals.
    On my third prius, both the first two lost about 10mpg's between year two and year three.
  6. whovian10
    New York
    Thanks. At least now I have a starting point on where to look.
    The commute is why I have a Prius. I'll have to take a look at this.
  7. MrMischief
    MrMischief Active Member
    426
    443
    Denver CO
    Too many doughnuts?
    HobbsNick, bisco and Mendel Leisk like this.
  8. whovian10
    New York
    Haha. I do pass 4 Dunkin Donuts on the way to work.
  9. Felt
    Felt Senior Member
    1,624
    603
    Mountain West
    My guess ..... 58 to 60 mpg was not the norm. You were driving more conservatively, and maybe even subconsciously .... hypermiling. Doing so is not as comfortable and is sometimes inconvenient.
    52-55 is much more normal. In time you relaxed, and do not make the best effort to maximize fuel efficiency. I agree, weather, tires, weight are all factors as well.
    In my G3 .... I was able to get between 65-69 mpg, but it required steady driving at 45 mph, no quick acceleration, no passing, and no stopping. Be grateful for 52-55 mpg ... after all, that is what was promised when you bought the car.
  10. fuzzy1
    10,170
    You obviously don't have the same tires now as you had the first two summers. What tires are on it now?
  11. Blizzard_Persona
    1,787
    944
    Pa.
    2023 Prius Prime
    XSE
    If they were the same, they should be running more effiently since they would be slicks right?
    :D;)
  12. bisco
    49,494
    i never pass a dunlin donuts.:oops::coffee:
    Felt likes this.
  13. RRxing
    RRxing Senior Member
    2,520
    1,791
    NEPA
    50 mile R/T in NYC traffic for me. My seven year average (per spreadsheet)? 48 mpg. Started around 52 mpg, lowered a bit over the years. I'm still happy with the car at 100,100 miles and plan to run it for another 100k. (No noticeable oil consumption, btw...)
  14. ALS
    ALS Active Member
    590
    294
    Pittsburgh
    Did the gas stations around you start changing over from E10 to E15 and you didn't notice. I got the shock of my life when I filled up with E10 for the first time and watched my fuel mileage drop like a rock over straight gas.
  15. FinToy
    FinToy Active Member
    145
    141
    Finland
    Does it really affect that much? They started adding ethanol to fuel here also and I was thinking perhaps I should try and use the version without it. Thanks for the tip, need to try it with next tank!
