Mileage drop after major crash.
Discussion in 'Gen 3 Prius Fuel Economy' started by FishHawk, Dec 2, 2010.
  1. FishHawk
    FishHawk New Member
    176
    I had a major accident and the small battery had to be replaced over Nine thousand dollars of repairs. Now my mileage has suffered. I can't seem to break into the 40 or 50mpg range. I'm hoping this is due to the cold weather . If not I'm going to dump the car.
    FishHawk.
  2. GrumpyCabbie
    GrumpyCabbie Senior Member
    6,722
    2,121
    45
    North Yorkshire, UK
    Could be anything. What was the damage? Where was it? What was repaired and what was replaced?
    The mileage drop could be the cold weather, it could be new tyres/tires bedding in, it could be the wheel alignment etc.
  3. ETC(SS)
    6,542
    Are you saying that you're getting LESS than 40-MPG?
    Depending on your driving style, that's a pretty big drop. I'm not a hypermiler, and I'm knocking down 55+.
    Depending on what was hit, and what was replaced/repaired, I would look inder the car to see if they replaced all of the goofy plastic 'underspoilers'---or whatever you call them. Did they replace a wheel? If so you might be dragging a corner from unrepaired damage in something like a bearing assy, missaligned suspension component, etc.... Tires, if replaced by non-HRR types, and not properly inflated could also be part of the problem.
    Too many possibilities without knowing what was bashed in.
    A 9,000 repair bill indicates pretty extensive damage---even in a Prius, but I'd still expect to get a car back that functioned approximately like it did before the incident.
    Since your car now has a sullied title history, you have a pretty big incentive to get to the bottom of what's not working properly, and continue to drive it---unless you're one of the fortunate few that can shrug off four figures in depreciation and drive whatever you want to.
    If this is the case, go pick out another one, trade yours in and put the whole thing behind you.
    Good Luck.
    Let us know how it shakes out!!!
  4. kingoftheding
    kingoftheding New Member
    Austin, TX.
    definitely agree with the tires and alignment issues. did they use OEM parts or after market. I would ask the body shop or look at your estimate you may be pulling around a little more metal.:D
  5. FishHawk
    FishHawk New Member
    176
    Both the rear end and front end was damaged. They had to replace the small battery. I'm getting about 44.5mpg now which was better then the first day I got the car back. It has 90k on it so I'm going to sell it. FishHawk
