Mileage dropped from 46 to 39!!! How?
Discussion in 'Gen 2 Prius Fuel Economy' started by ewxlt66, Dec 6, 2012.
  1. ewxlt66
    ewxlt66 Active Member
    535
    186
    Dana Point, CA
    Driving patterns almost the same save for 1 extra 60 mile freeway trip.
    Never above 70mph.
    As much glide as possible.
    But now 39mpg?
    Any ideas as to what's going on?
  2. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    ewxlt66 likes this.
  3. ewxlt66
    535
    186
    Dana Point, CA
    49,433
    how about the weather?
  5. ewxlt66
    535
    186
    Dana Point, CA
    Sunny SoCal. Been 70s in the day and a oh-so-harsh 50s at night.
  6. bisco
    49,433
    no need to rub it in.:cool:
    ewxlt66 likes this.
  7. ewxlt66
    535
    186
    Dana Point, CA
    Jim, I tried to check it using the DIY method but couldn't get into the mode where the car will tell you. Holding down Menu and lights on/off 3xs and nothing except normal info screen.
  8. SteveLee
    SteveLee Active Member
    645
    180
    North Carolina
    I
    I believe the sequence is:
    - Press and hold the MFD Info button, then turn the headlights on and off three times to enter Maintenance mode; release Info
    button
    - Press “Menu” (on screen)
    - Press “Display Check”
    - Press “Vehicle Signal Check” - the battery voltage is shown and should be about 12.4 to 12.8 Volts (normal for an unloaded
    battery)
    - Again without brake pedal, press Power button and release to put a current load on the battery - the voltage should stay
    above 12.0V (if less than 12.0V the battery is not well, or there is a fault or unusual load somewhere)
    - Press brake pedal and press Power button once to enter "Ready" mode - the battery is now charging at about 14V (if less than
    13.6V or more than 14.4 there may be a problem with the charging circuit)
    - Turn car OFF to leave Maintenance mode
    Read more: http://priuschat.com/threads/weird-stuff-happening-mpgs-dropping-test-the-battery.73400/#ixzz2ENuBCSHk
  9. ewxlt66
    535
    186
    Dana Point, CA
    This is what I did. Nothing comes up after I do the headlight sequence.
    As of this AM the passenger seatbelt light is blinking too. Seems to be the battery I guess.
  10. ewxlt66
    535
    186
    Dana Point, CA
    I got it to work this time.
    Battery is showing 10.2v.
    I guess it's time!
    Any one has AAA install a battery?
  11. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
  12. curtis0916
    curtis0916 Junior Member
    Abilene, KS
    I did this check and got the following results, do these indicate an issue or just that I need to keep an eye on the battery as we enter winter here in Kansas? I have owned my 2006 Prius for a little over 2 years and am not sure when the current battery was installed. Thank you for any assistance you can provide.
    Press “Vehicle Signal Check” - the battery voltage is shown and should be about 12.4 to 12.8 Volts (normal for an unloaded battery) (MY READING WAS INITIALLY 12.1)
    - Again without brake pedal, press Power button and release to put a current load on the battery - the voltage should stay above 12.0V (if less than 12.0V the battery is not well, or there is a fault or unusual load somewhere) (MY READING WAS 11.8)
    - Press brake pedal and press Power button once to enter "Ready" mode - the battery is now charging at about 14V (if less than 13.6V or more than 14.4 there may be a problem with the charging circuit) (MY READING WAS 14.1)
  13. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    I would not worry unless I had other symptoms, then I would mail order a Optima from elearnaid at the first real symptom. Think of the test as a way to know if your symptoms are battery related.
    richard schumacher likes this.
  14. ewxlt66
    535
    186
    Dana Point, CA
    Battery replaced. Passenger air bag light has stopped blinking. Let's see if the mpgs have returned.
  15. SteveLee
    645
    180
    North Carolina
    I
    As a point of interest I've discovered this sequence also works just turning on the parking lights 3 times instead of the headlights. I like that much better. I hope your MPG 's improve also.
    ewxlt66 likes this.
  16. ewxlt66
    535
    186
    Dana Point, CA
    Thanks Steve.
  17. wek
    wek Junior Member
    Durango, Colo
    I have a 2005 prius w/ 105,000 miles on it. My summer gas mileage was around 48ish mpg. I do a lot of mountain roads. In Dec it dropped to 39mpg. After reading these threads last week I checked the start Batt (11.9 after sitting a few hrs) and 13.9 while on. My dealer replaced the batt last summer. I also replaced the spark plugs (this got me more power while driving and better gas mileage. Thanks for the tip!! Is there a sensor I can check for carbon build-up?
  18. SteveLee
    645
    180
    North Carolina
    I
    We would expect the mpg to drop some in the winter but that may be too much. It is not clear how you got your battery readings. You should report all 3 readings in the sequence outlined above. If you did it this way your 11.9V is low. The range between the 1st and 2nd number (that you didn't give) gives an indication of the health of the battery, as does the last number that indicates the charging amps.
    A new battery is not necessarily a fully charged battery. After you report all 3 numbers you could try slow charging with 2 amps or less. You can do that at the jump point under the hood. Be very careful to connect it correctly the first time. You may not get a second chance if it is connected backwards even for a split second. The cost of repair can be 4 figures.
  19. wek
    wek Junior Member
    Durango, Colo
    Thanks for responding Steve. After a cold night the 1st batt reading was 11.9 with a load on it was 11.5 and powered up was 13.9. I fear the 11.5 for the loaded batt is weak especially for a 6 month old dealer battery. I talked to my dealer guy and he said those readings have nothing to do with the battery life. He gave me some line about it has no alternator and there is something else thats is pulling power from it. I think they are trying to get out of replacing a bad battery they put in. What simple explaination can I tell them so they look at this battery seriously?
  20. SteveLee
    645
    180
    North Carolina
    I
    Well, they do have to do with present battery health. The 11.9V is about 50% SOC and much lower than it should be considering the age of the battery if the car is charging, which it is as we see with the 13.9V reading. It's true it has no alternator but it does charge this battery and it is doing that. The range between the 11.9 and 11.5 readings doesn't seem to be an unusual drain. I'm not a battery expert but others here are very knowledgeable and with these readings should be able to give more info. I would probably try trickle charging it to see if it will hold a higher charge. It should not be reading 50% state of charge at 6 months old. What is the warranty period for the battery? I doubt this is the car's fault.
