Mileage for first service?
Discussion in 'Gen 5 Prius Main Forum' started by Ultra, Jun 11, 2024.
  1. Ultra
    Ultra New Member
    Illinois
    2024 Prius
    LE AWD-e
    At what odometer reading is the first service recommended? I’m only at 4600 mi, but the dash says maintenance soon (or something to that effect) when I start the car, but no other codes or messages appear. 2024 LE AWD.
  2. douglasjre
    douglasjre Senior Member
    1,877
    653
    Orlando, FL
    500 miles. You're way overdue. New tundras are having trouble w mfg debris. I wouldn't risk it
    Then do oil changes every 5k
    Danno5060 and ColoradoBoo like this.
  3. Ultra
    Ultra New Member
    Illinois
    2024 Prius
    LE AWD-e
    The maintenance soon notification just came on around 4500 miles. Is Toyota’s official recommendation an oil change at 500 miles? Or is 500 miles just a personal preference when being cautious?
  4. Trollbait
    11,560
    Toyota just uses an odometer timer that goes off at 5000 miles. IIRC, the maintenance schedule of what services for each 5000 mile point is in the warranty guide. Standard oil changes are every 10k miles, so the 5000 mile point will mostly just be visual and fluid level checks, maybe rotate tires.
    Was your previous car a Honda or GM?
  5. Mendel Leisk
    38,726
    Have you had a look at the Toyota USA Warranty and Maintenance Booklet? It should be in the glove box.
    And yeah, all the intervals are miles or months, whichever comes first.
    FWIW, I do think the miles/months thing starts to unravel, if you're super low miles. That's our scenario; I was doing oil changes every 6 months (per Toyota Canada 3rd gen recommendation), doing an oil change spring and fall. Then spring before last, did an oil change, entered it in my log, and it was barely 1000 kms since my last change. Resolved to make it once a year from then on.
    Addendum:
    Honda uses a Maintenance Minder, which is light years ahead: does appear to be monitoring various parameters, gives you countdown in percent to next service, and when it's down to 15% remaining, displays an alpha/numeric code that you can look up in the owner's manual, see precisely what needs doing. I don't think the dealerships like it...
    Anyway, one thing it says: if the maintenance minder has not gotten down to below 15% in a year, change the oil anyway.
    Another factor, and again the dealerships ignore it, the Maintenance MInder distinguishes between "oil change" and "oil and filter change", and alternates between the two.
    #5 Mendel Leisk, Jun 12, 2024
    douglasjre likes this.
  6. bisco
    49,488
    our toyota dealer haunts us when it is time for service.
  7. Preebee
    Preebee Senior Member
    854
    750
    Midwest
    2023 Prius
    The manual says to "obtain maintenance" at 5,000 miles or 6 months, whichever comes first.
  8. NullDev
    NullDev Junior Member
    Ohio
    2024 Prius Prime
    XSE
    I've always been a Honda driver (and oil/brake/tire maintainer), so it's taking me a bit to get used to how Toyota does their service intervals. While I do like that the initial services are free, I feel that Honda's methods of determining exactly what and when to do things is better tied to how the car is used. Temps, aggressiveness, and mileage all factor into how the maintenance minder counts down. The icing on the cake would be if it could detect the actual state of the oil and quantity of suspended particulates. One can dream....
  9. Trollbait
    11,560
    GM has a similar system. Maybe some others have moved to an oil monitor, but many simply don't want to pay for it. Even a basic engine hours meter for PHEVs would be a better way of handling oil change times.
    HacksawMark likes this.
