Mileage has gone down dramatically
Discussion in 'Gen 2 Prius Fuel Economy' started by Condor127, Mar 4, 2015.
  1. Condor127
    Condor127 New Member
    I have a 2006 Prius with 165K miles. My MPG suddenly went down 20% (47 to 38). Tires are fully inflated. I did change to high-mileage oil at last service, could this be the cause?
    Thanks in advance for any input.
  2. TokyoRose12
    TokyoRose12 New Member
    Richmond, VA
    I am having the same issue with my 2006 Prius - mileage gone from 50 to 38 and all service done at dealer every 5K. I would appreciate any information or guidance to regain my mileage.
  3. nh7o
    nh7o Off grid since 1980
    1,686
    338
    Hawaii
  4. Easy Rider 2
    Easy Rider 2 Senior Member
    1,584
    257
    Ocala, FL
    Not likely that the difference in oil is a factor at all........unless you put in something like 20W50 and it's still cold where you live.
    If your 12 V battery is over 5 years old, I'd recommend changing it now.
    After that, you need to get a scan done because a really LOT of things could be factors.......like a dragging brake just for instance.
    Some will show up on a scan and some won't.
    You need a good mechanic.......but those seem to be rapidly becoming extinct.
  5. bisco
    49,500
    winter gas, bad weather, dirty throttle plate.
