Mileage Improvement Over Time
Discussion in 'Gen 3 Prius Fuel Economy' started by impact10, May 11, 2011.
  1. impact10
    impact10 Junior Member
    44
    Tennessee
    I have almost 22K on my 2010 Prius, and will have had it two years in August. I am regularly getting 55 mpg in town, where in the past it was about 50-52 max. Has anyone experienced improving mileage over time? I wonder if it's more improved driving habits, or perhaps higher efficiency as it gets older?
  2. adamace1
    adamace1 Senior Member
    1,403
    191
    Charlotte, NC
    Not me from around 100 miles on the car to 41k i got now i never noticed any better mpg. i would think your seeing warmer temps help your mpg out.
  3. Skoorbmax
    Skoorbmax Senior Member
    2,641
    264
    Western NY
    Or driving habits. There isn't really anything going on that should improve mpg 3-5 mpg.
  4. wstevensiv
    wstevensiv New Member
    84
    Little Rock
    I have read on here that as a prius gets out of puberty its mpg goes up...no joke!
  5. David Beale
    David Beale Senior Member
    5,963
    1,983
    Edmonton Alberta
    There are many factors involved.
    1. The driver is learning how to actually drive efficiently. I suspect this is the dominant factor.
    2. The tires had to break in, but this happens in a few thousand miles.
    3. The traction battery will become more efficient after about 3-4 months of use.
    4. The ICE will break in, becoming more efficient (mostly due to lower friction losses). This takes about 10,000 mi.
    5. The ECU will "learn" how to operate more efficiently. This takes a few months.
    All this is difficult to measure, with all the variables involved with mileage, such as seasonal variations, differences in use over time, tire pressure changes, fuel changes, etc etc.
  6. tumbleweed
    tumbleweed Senior Member
    4,067
    687
    Eastern Oregon
    I suspect it is learning to drive a HSD car. With my first Prius I think the mileage did improve over the first few thousand miles as I learned all the tricks. With this one my mileage hasn't changed from when it was new.
    The car itself should be broken in and limbered up enough after the first 1K to 1.5 K miles to provide maximum mileage if driven correctly.
  7. rcf@eventide.com
    173
    85
    Sedona
    As tires get older, their radius decreases due to tread wear, which means that there will be more revolutions of the tire per mile driven. While this probably doesn't affect your actual mileage, it will affect your computed mileage, although only by a small amount. On a Prius, a 1/4 inch change in tread depth from new to worn would change the computation by about 1mpg.
  8. TonyWilkey
    TonyWilkey Member
    99
    25
    Kansas
    After 13K miles my MPG trend is definitely increasing with mileage/time.
    Tony
  9. alfon
    alfon Senior Member
    1,370
    270
    seaside, oregon
    We purchased our Prius two years ago. We went on our honeymoon to Reno NV. I believe the round trip calculated was 52 MPG or so.
    Car had only about 400 miles on it. It may be 2-3 mpg better now probably due to the Michelin Energy Tires we replaced with the factory Yoko Avid.
    al
  10. rebenson
    rebenson Member
    364
    43
    Suburb of Chicago
    1st year coming up, I'll let you know...
    Winter and change in some of my driving (short trips in a harsh chicago winter).
    2010 - 51 MPG
    2011 - 47 MPG (but going up, have over 50MPG last 1K miles this year)
    And this is actual, not off the screen....
  11. fuzzy1
    10,254
    [mpg graph snipped]
    Part of this is seasonal. You bought it in the worst MPG season, and the best MPG season is rapidly approaching. [We hope. In my region, spring is seriously delayed this year.]
    Part of this is also tire breakin, but I think at least half your improvement is continued fine tuning of the nut behind the wheel.
  12. cyclopathic
    cyclopathic Senior Member
    3,292
    547
    2014 Prius c
    Yes it gets better and there are a several factors at work:
    - mechanical parts break in and friction reduces
    - (probably the most) tires improve MPG as they wear out (up to 20% less rolling resistance)
    - improved driving habits
    - temperatures going up in spring, summer blend gas tend to improve MPG
  13. mainerinexile
    mainerinexile No longer in exile!
    403
    73
    Maine
    My gas mileage definitely went up after about 10K, even with cooler weather coming on. When I bought it in April, I struggled to get 50mpg. At the end of the summer, I was regularly getting 55 mpg without trying. This spring, I'm getting 60 to 65 mpg on my daily 50 mile commute driving 45 to 55 mph.
