Mileage low after replacing new hybrid battery
Discussion in 'Gen 3 Prius Technical Discussion' started by Ashikur Rahman, Nov 4, 2024.
  1. Ashikur Rahman
    Ashikur Rahman New Member
    Dhaka Bangladesh
    New hybrid battery replacement but milage fluctuating. When driving 70 or Avove it’s showing 19/20 . But little jam instant drip 8 km. I am in tension. What should I check ??
  2. Mendel Leisk
    40,498
    I’m thinking 19/20 is kilometres per liter? If so, that converts to 47 miles per US gallon. And this is at speed 70 kilometres per hour?
    Then it drops to 8 kms per liter (19 mpg) if you’re slowed due to traffic jam?
    All of this seems normal. I would continue driving, calculate based on liters required to refill the gasoline tank and the distance travelled since last fill. Do this for several tank fills, and you will have a better estimation.
    How is the display of hybrid battery state of charge; does it go up and down gradually, stays between half and three quarters usually?
    bisco and Brian1954 like this.
    51,043
    is it a new oem battery from a toyota dealer?
