Mileage Observation
Discussion in 'Gen 3 Prius Fuel Economy' started by ranger04, Jun 16, 2011.
  1. ranger04
    ranger04 New Member
    canada
    I went to fill up the other day and had the following #'s:
    Trip: 740 km
    Distance before fueling indicator: 26 km
    Fuel amount into car to full capacity: 35 litres
    Since the fuel tank is a 45 litre capacity this means I had 10 litres left. The fuel indicator was on the last LED (half) and flashing. I'm averaging about 4.5 litres / 100km so would it be safe to assume I could go another approximate 200kms? Is there some sort of reserve capacity for the prius? Thx.
  2. alfon
    alfon Senior Member
    1,370
    270
    seaside, oregon
    I have noticed that when I get gas when the pump first shuts off
    you can still put in 2 US gallons of gas before it shows at the filler
    neck, if you take your time.
    alfon
  3. ranger04
    ranger04 New Member
    canada
    So this would mean that instead of having 26 kms left the car actually has conservatively ~ 160 kms before the tank goes dry?? Perhaps the computer is programmed so that a person doesn't run out of fuel?
  4. nerfer
    nerfer A young senior member
    2,507
    235
    28
    Chicagoland, IL, USA, Earth
    No, it means that the station's pump turned off too soon, and your tank wasn't totally full when you left the station.
  5. ranger04
    ranger04 New Member
    canada
    The pump didn't shut off too soon. I always fuel up at the same place & I also top it up even though it may have stopped on its own.
  6. vday
    vday Member
    312
    Israel
    That's normal I have 7-8 liters (2 US gallons) lest when the led starts to flicker;)
