mileage tips under challenging circumstances
Discussion in 'Gen 3 Prius Fuel Economy' started by draheim, Apr 2, 2010.
  1. draheim
    draheim Member
    124
    Seattle
    2018 Prius Prime
    Greetings all, this is my first post on the forum. I am among the hordes of new Toyota owners, tempted by an unprecedented 0% down, 0% APR deal on a shiny new silver 2010 Prius II. I've had the car for less than a week and so far I love it. Wish I'd gotten more for my trade-in, but that's another story...
    I have been doing some research on optimizing my mileage and have to say, it appears that my typical car use is not likely to produce great results. In the morning I drop off my daughter at daycare, then drive to the nearest bus stop. At the end of the day I reverse the process. Typical drive times are probably 8 minutes, not enough time to warm up the engine. Add to that Seattle's almost all stop-and-go traffic, and many steep hills, and I find myself going into full Power mode more often than I'd like. After about 90 miles I think my current MPG reads around 37.0. Over the last 10 years I probably put 3K per year on my old car, so I definitely drive a lot less than the average driver.
    So my question is, given these circumstances (which aren't likely to change much), is there anything I can do to make the most of the hybrid technology I paid for? Certainly the main reason I bought this car is for its improved mileage and smaller carbon footprint; it's why I picked the Prius over the hybrid Camry. I don't expect miracles, but I am interested in learning more about how I can get closer to the 50 MPG I was hoping for.
    Please let me know if you have any suggestions. Thanks!
  2. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Welcome!
    That is a tough situation you got. Not ideal for the Prius for sure. Plug-in maybe. A conversion would be fairly costly and you probably would not gain your money back.
    Perhaps upgrade to the Plug-in Prius in a year or two?
    I am sure others will have more to say.
  3. JimboPalmer
    12,470
    6,876
    Greenwood MS USA
    :welcome:
    It is my naive opinion that the Toyota Engineers were told to make the least polluting car they could and the Prius is the result. While owners may buy it for gas mileage, that is a byproduct of GIGO. If you don't add much gas, you have less gas to clean up after.
    When you start the Prius the computers priorities are protect the battery, protect the engine, get the least 'cold start' pollution, etc. Once warm, the computers try to reduce emissions by not ingesting gasoline. To skip the cold steps is unwise unless you want to pay for a new battery, new engine, or pollute like mad. (A plug in hybrid, or electric car would perhaps have served you better)
    One technique you can try if your electric bill is cheaper than your gas bill. You can add a Engine Block Heater, and plug in the Prius for 90 minutes before driving it. (perhaps on a timer) This will speed up the 'cold start' phase of driving and get you quicker to the 'use less gas' phase. (I doubt it will fully warm up in 8 minutes, but it may)
    PriusChat Shop : Toyota Prius Engine Block Heater [Prius EBH] - $59.00
    Living in the PNW, your electricity may well be less polluting than your car, and cheaper to run for 90 minutes than 8 minutes of gasoline. Good Luck!
  4. Felt
    Felt Senior Member
    1,624
    604
    Mountain West
    Great to have you aboard.
    JimboPalmer gave you great advise.
    As long as you understand your mileage will not be fantastic, you will be satisfied. Then on weekends, and vacations, you will be able to enjoy the atributes of a really remarkable vehicle. Also realize, that even though your Prius is not delivering it's best due to your circumstances, it is doing better than another conventional car in the same situation.
  5. efusco
    efusco Moderator Emeritus
    19,891
    1,194
    Nixa, MO
    +1 on the EBH, but I recommend at least 2-3 hours of pre-warm time to get maximal heating at minimum expense.
    And just remember that even at 37mpg and 3k miles/yr you're still just using ~80 gallons of gas a year and probably filling up only once a month....or less! You'd be a great candidate for a commuter type EV with the type of driving you do, but since you had to 'settle' for a Prius I think you're doing OK. Also, you will probably realize better mileage as the car and tires break in and as the weather warms up.
    If you really really really want to see better numbers and are willing to work at it and change your driving style, check out CleanMPG, An authoritative source on fuel economy and hypermiling for some serious hypermiling tips.
  6. ursle
    ursle Gas miser
    1,049
    192
    NH
    Right, worst case scenario, just keep in mind that any other car is going to get below 25mpg.
    The block heater is a good idea if it's convenient, that five or ten minutes of heating the engine to get it to stage 4 takes a lot of gas, and just as YOU get there you shut the car off so to shave it (warm up) to a minute or less would be beneficial in the long run.
    Tire pressure 44f 40r, don't use the air conditioner
    Great first post
  7. Dark_matter_doesn't
    Dark_matter_doesn't Prius Tinkerer
    691
    151
    Seattle, WA
    I'm in your "neighborhood" (so to speak). My commutes are a bit longer (10 - 15 miles one-way), and the hills do tend to reduce mileage. I've been partially blocking part of the lower front air intake (radiator) with some 1" foam pipe insulation that's slit to fit around existing pipe. It's added a couple of mpg in cold weather. It's a few bucks from Home Depot. Search here for radiator blocking strategies for install descriptions.
    It may be challenging to find someone in this area that knows how to install the block heater. My local dealership never heard of them!
  8. Tideland Prius
    16,445
    +2 on the EBH. Even at 32°F, you'll see benefits (it's like starting with the car always warmed up). Higher tyre pressures can help too. Your situation really is a challenging one.
  9. JimboPalmer
    12,470
    6,876
    Greenwood MS USA
    Canadian dealers sell them as dealer installed options, a road trip to British Columbia may be in order.
    Sunrise Toyota
    30210 AUTOMALL DR
    ABBOTSFORD BC V2T 5M1
    604-857-2657
    Metro Lexus Toyota
    625 FRANCES AVENUE
    VICTORIA BC V8Z 1A2
    250-386-3516
  10. hobbit
    hobbit Senior Member
    4,089
    468
    Bahstahn
    Take a nice long road-trip! Post pix!
    _H*
  11. JimN
    JimN Let the games begin!
    7,028
    1,117
    South Jersey
    EBH, block the grill, increase the tp, and ensure oil is not overfilled is about all you can do. Your FE is about what I would expect. When you take the car on longer road trips you'll see the higher numbers.
  12. fuzzy1
    10,335
    The ferry ride alone, to and from Victoria, will likely cost many years of gas savings from the EBH. Even Abbotsford is a long way just to get one installed. Another excuse -- a B.C. vacation! -- is needed to justify the trip.
    To OP:
    3k miles per year does not make a compelling case to switch from a normal gas hog to a hybrid. Your Prius' 37 mpg is far better than a regular non-hybrid can achieve in similar circumstances, but the use of public transit has likely already claimed much of the potential fuel savings.
    I second the pointer to CleanMPG.com. Look first for 'Beating the EPA' and 'Pulse and Glide and Warp Stealth in the Prius II'. Once the engine is warm, stop-and-go traffic is a good opportunity to push up your MPG, if you can avoid full power.
    I no longer count the number of GenIIIs spotted in a day, but did notice four fellow Silvers once this week. Maybe you were the one with a dealer placard in the plate holder. Welcome to PriusChat!
  13. JimboPalmer
    12,470
    6,876
    Greenwood MS USA
  14. cwerdna
    cwerdna Senior Member
    12,544
    2,123
    SF Bay Area, CA
    +1 on all of these. The EBH is the most expensive, but likely still helpful. Blocking the grille is cheap. The current weather in the Seattle area is fine for blocking the grille, esp. in the morning. KOMO 4 news is currently forecasting a low of 39 F and high of 54 F from Sat thru Fri. When it gets warmer, one should definitely remove it. (I don't know of a good threshold/rule of thumb as to when's a good time to remove.)
    With ScanGauge, one could monitor coolant temp (if it gets too high, remove the blocking) but unfortunately not inverter or MG1 or MG2 temps, AFAIK.
    Also, don't use auto on the HVAC system and keep the fan off when the ICE (internal combustion engine) is cold. Heat on high, but fan off is ok when you're stopped or in slow traffic.
    If the ICE is warmed up enough and HVAC is off, it will shutdown. If you leave the heat on, the ICE will run to provide cabin heat, wasting gas. Turn on the ICE only when the car is warmed up enough (you can't monitor this w/o ScanGauge or equivalent), on harder acceleration (where it must run anyway) or at speeds >42 mph. (Gen III owners, please chime in if the 42 mph is wrong.)
  15. vday
    vday Member
    312
    Israel
    I agree with Felt
    I also wrote that I finally hit 40 after getting about 37
    I try to keep in mind that my precious car over 85K miles got 23.
    Longer trips on flat surface really help.:)
  16. dan2l
    dan2l 2014 Prius v wagon
    654
    263
    Vancouver Wasington
    2014 Prius v wagon
    First get the scangauge. The 0 rpm will help you to learn when the ICE is on or off. Optimized mileage is very dependent on the drivers skills at optimizing the system.
    Second grill blocking. I block all the lower and 1/2 the upper and the scangage indicates that I am OK.
    Third, be careful with the use of the heater and defrosters. I don't use the defroster as it overrides the ECO mode. I use the heater with the air going to both the feet and defrost, but only until the fog is gone, and mostly when the ICE is running anyway.
    Fourth the EBH. You can get it installed at Pacific EV in Bellevue
    Thanks,
    Dan
  17. Tom183
    Tom183 New Member
    652
    65
    Maine
    I love my Prius, but you should trade yours in for a Leaf. 3k per year, with lots of short, stop&go trips, sounds ideal for an EV with regen braking.
  18. cwerdna
    12,544
    2,123
    SF Bay Area, CA
    Well, ScanGauge has a MSRP of $170 (can't get it for much less than $150, IIRC). Blocking the grille w/pipe insulation (on my 2nd gen) is <$10. EBH is >$100 installed.
    The order I'd go in is proper tire pressure (free), use heater properly (free), block grille (cheap), then ScanGauge and/or EBH.
    ScanGauge may/may not yield huge improvements since it all depends on whether the driver is willing/able to adjust their driving based on feedback from SG. I sometimes end up in traffic conditions that are far too congested for me to even look at my SG safely or don't allow me to do anything other than go w/the flow, otherwise I'd be obstructing traffic or pissing others off.
    I use mine and a # of XGauges but bought it more out of curiosity than knowing I'll benefit. It's rather expensive as an ICE on/off indicator. But, having it can help warn you that you should removing your grille block.
    EBH for sure will yield benefits.
  19. Kimoy
    Kimoy Member
    168
    24
    Chicagoland
    How long do you need to warm up your car before you first drive it in the morning? How would you know the car is warm enough to drive and safe to not damage the cells?
  20. cwerdna
    12,544
    2,123
    SF Bay Area, CA
    0 seconds. Don't bother. Your best warmup is just to drive. If you're sitting there letting the ICE idle, you're needlessly wasting fuel.
    What would "damage the cells?" The Prius doesn't have a battery heater. It could get heated by resistance or cabin heat.
