MillerCat Rivet Nut Tool
Discussion in 'Gen 2 Prius Main Forum' started by RickBthere, Dec 17, 2021.
  1. RickBthere
    RickBthere New Member
    Silver Spring,MD
  2. xliderider
    xliderider Senior Member
    7,876
    3,117
    Honolulu, HI
    No, that is a standard blind rivet tool. It can't set rivet nuts.
    #2 xliderider, Dec 17, 2021
    SFO likes this.
  3. Rebound
    Rebound Senior Member
    3,964
    2,613
    Portland, OR
    Harbor Freight makes a good one. That’s what I used.
    10 in. Professional Rivet Nut Setter Kit
    When you install the cat shield, take the cardboard box the shield comes with and slide it under your car. Then you’ll drill out a few holes under the car. After you drill out all the holes, slide the box out. Now when you complete the install, your back and hair won’t get covered in tiny metal shavings.
    Trust me.
    Raytheeagle and xliderider like this.
  4. xliderider
    7,876
    3,117
    Honolulu, HI
    Also, when you drill the holes in the rails under the car, use oil on your drill bit. It will keep the bit cooler and it will cut through the steel much faster.
    Overheating the bit can cause the bit to lose its temper and dull faster.
    PriusCamper likes this.
