Mine is bigger than yours...
Discussion in 'Fred's House of Pancakes' started by pilotgrrl, Dec 7, 2017.
  1. pilotgrrl
    pilotgrrl Senior Member
    891
    1,797
    Chicagoan in TX
    RCO likes this.
  2. Dxta
    Dxta Senior Member
    1,932
    769
    Lagos
    The competition is already heating up.
    I believe with time, other auto brands, battery makers would beat Tesla's battery capacity and timeline.
    Dxta
  3. WilDavis
    WilDavis Senior Member
    2,493
    2,154
    49
    …oh, that is so "…My Invisible Friend can beat up your Invisible Friend!" :eek::rolleyes:
    RCO and pilotgrrl like this.
  4. Why are they doing this if Li-Ion batteries degrade due to dendrites and you can't use the full capacity? Why are we not fixing these problems first... and then building these MegaWatt/GigaWatt battery storage systems?
  5. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    Because you do exactly what Toyota did. You make a big battery and use a smaller portion of it. That's why the original Prius for example only went roughly between 40% and 80% even though the screen showed 0% and 100%. When you build a big bank like this in an area with good stable power, it can be massaged carefully and gently to extend its life. I assume that's what they're going to do.
    scona and bhtooefr like this.
  6. That's my point. What a waste of potential capacity for something so huge! Why not fix it so that when the time comes for a 1 GW system, use all of the 1 GW instead of being limited 80% of the useable capacity?
    And still use only 80% of its actual capacity? Again, wasted energy and manufacturing.
  7. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    That's how all batteries work. You never want to discharge to nothing or charge to 100%. Even the best lithiums top out at around 96% on the high end and 3%-4% on the low end making it about 90% usable capacity. That's the design, there is nothing to fix.
    RCO likes this.
  8. Dxta
    Dxta Senior Member
    1,932
    769
    Lagos
    ...and if they were to off limit the algorithms that controls the charging/discharge to ...., that means people have got to spend more kind of, buying batteries. I think the technology is cool.
  9. bwilson4web
    16,010
    Because you can only build with the technology in hand even if it isn't perfect. There is an old saying, 'Never let perfect be the enemy of good enough.'
    The first Wright flyer was a terrible airplane compared to what we fly today. But it was a critical first step and aviation progressed.
    So what if these batteries wear out ... by then better batteries will be available to replace them.
    WilDavis, RCO, fuzzy1 and 3 others like this.
  10. bhtooefr
    bhtooefr Senior Member
    1,396
    1,489
    Newark, OH, USA
    That's exactly it - there's a demand for energy storage systems now, not 10, 20, 30 years from now.
    Needing more batteries now to meet the capacity target, or wearing out batteries sooner, can still reduce overall emissions of CO2 and of criteria pollutants. Sure, you have higher battery manufacturing emissions, but they more than offset the emissions of natural gas peaker plants that you would've run instead of the battery storage.
    RCO, Trollbait and bwilson4web like this.
  11. Well I disagree with that saying. And certainly in this case.
  12. mikefocke
    3,899
    1,755
    Sanford, NC
    I presume you have replaced the anode in your water heater, right? (and the heating elements for that matter). Because your water heater is probably not able to be 100% efficient unless you have just replaced it or done those parts replacements. So you may be spending $ to heat water that you don't have to. My point is we all live with less than optimum solutions. And buy less than optimum things.
  13. fuzzy1
    10,335
    "Wasted energy and manufacturing" would be to use the batteries in a manner that shortens their overall cycle life expectancy. Restricting their per-cycle capacity increases their lifetime throughput.
    Future battery technology should do better. But we won't get there without using and building upon what we have right now.
    Trollbait and scona like this.
  14. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,080
    Columbia, SC
    Hmmmm. Industry.....if we waited until a product was perfect before it was put into use, we would still be waiting for the Model T to come off the assembly line. Pretty much EVERYTHING is produced once its design is determined to be "good enough". Otherwise a company would go bankrupt spending money on design teams with no income from sales. The kinks get worked out after it's in production and in use. The next stage of improvements is based on the current product in use and weaknesses discovered (imperfections). Iteration after iteration after iteration.
    It's 11:30pm and you're tired as all heck, but here's what you've been told you have to do before you go to bed. Stand so the tip of your nose is 10 feet away from a wall. Every minute, move closer to the wall so that the distance between the tip of your nose and the wall is cut in half. When your nose touches the wall, you can go to bed. Are you ever going to be able to go to bed? Or after about 5 minutes, are you going to just say 'good enough' ? In a perfect world, you would never go to bed.
    Dxta and Guvna like this.
  15. RCO
    RCO Senior Member
    3,709
    5,185
    Cornwall
  16. bhtooefr
    1,396
    1,489
    Newark, OH, USA
    Flow batteries are a fantastic idea for fixed applications - really, the main reason for using Li-ion is the economies of scale due to EV manufacturing.
  17. RCO
    RCO Senior Member
    3,709
    5,185
    Cornwall
    True, but this is small scale ATM very close to cutting edge of development.
  18. WilDavis
    2,493
    2,154
    49
    …ask any competent surgeon to see if they agree with you! o_O:eek::rolleyes: ;)
  19. Trollbait
    12,346
    If we did it the way you wish, we'd be generating for more greenhouse emissions burning natural gas or coal for power than the manufacturing of the "wasted" battery portions, while waiting for perfect batteries that might never come to pass. Plug in cars reduce emissions by avoiding the burning of fossil fuels.
    Your stance in this thread while owning a Prime makes you a hypocrite.
    bhtooefr likes this.
  20. That's my point. Build better tech first before making these huge sources.
    No. I have no idea what that is and don't care.
    But I think that with these battery sources, these companies should devote more time/energy to better technology first, because I think that is more necessary and more important to address these issues on big battery plants, first and more promptly than wasting potential energy and lithium, than it would be to make other things in technology more efficient. How much pollution goes into building such a huge battery in the first place? And then you use only 90% of it? I think that they should use more efficient graphene-based polymers, and reduced dendrite formation, and I think that they can get closer to 95%-99% usable capacity, and thus cut down on manufacturing pollution that way.
    That makes no sense. Build better technology that uses closer to 100% of the batteries and not degrade its longevity before putting up these enormous battery operated sources.
    1. No it doesn't!
    2. It doesn't matter what car I have!
    3. How you would like it if I called you a hypocrite? How would you like it if I said: Your stance on something makes YOU a hypocrite, and because of whatever car that you have. See how it makes YOU feel!
    What does life-rescuing surgery have to do with anything??
    #20 Deleted member 111882, Dec 9, 2017
    Dxta and RCO like this.
