Mini-Me charging cable
Discussion in 'Prime Plug-in Charging' started by Marine Ray, Feb 23, 2021.
  1. Marine Ray
    Marine Ray Senior Member
    1,139
    947
    Sparks, NV
    Do they sell a shortened charging cable (say 3 feet or 6 feet) long? If not, can one be made? Could be used as second charging cable on trips, etc.
  2. Mendel Leisk
    41,879
    How long's the standard one? Wouldn't MORE reach be advantageous on a road-trip, where outlets might be not as convenient? Not sure. Why shorter, just more compact?
    MTN likes this.
  3. Marine Ray
    1,139
    947
    Sparks, NV
    Or perhaps the other way - keep the shorter for home charging and OEM for the trips.
  4. EdPalmer42
    EdPalmer42 Member
    135
    75
    2020 Prius Prime
    I bought a heavy-duty extension cord to give me a bit more range than the OEM cord. I think it's 3M (10ft.) long and 14ga. Much cheaper than a charging cable.
  5. Rich-T
    Rich-T New Member
    Bethpage, NY
    The original 110VAC charging cable fits with room to spare in the back compartment behind the battery (in front of the rear hatch door). In the 2021 Prius Prime there is a compartment cover that lifts up to expose this storage space. I was even able to add a 30 amp adapter so I could plug in at marinas. If you use that storage space, you won't need another cable.
    Jameson Roob likes this.
