Mini Vci 1.4 quick Q - will it read codes on a 2012
Discussion in 'Gen 3 Prius Accessories and Modifications' started by andreimontreal, Dec 23, 2019.
  1. andreimontreal
    andreimontreal Active Member
    347
    109
    28
    Montreal
    What the title said; looking to find out this asap. I need fast a mini vci to read codes on a 2012. I found this firmware 1.4 with Techstream 13 on amazon that can ship here tomorrow (amazon com has good reviews for that - I hope it works).
    From what I understand that will work to read codes just fine? It will limit me for certain setting mods and whatnot?
  2. tankyuong
    tankyuong Senior Member
    1,555
    661
    Central MO
    Software is free on internet but cord isnt
  3. andreimontreal
    347
    109
    28
    Montreal
    Not my question by far @tankyuong.
  4. Grit
    Grit Senior Member
    6,454
    4,188
    Wilkes Land
    Depends on the software version and build that is available.
  5. andreimontreal
    347
    109
    28
    Montreal
    The software version - it says in the link - it's v13.00.022 . The build: do you mean the car or the computer?
  6. Raytheeagle
    Raytheeagle Senior Member
    11,263
    15,512
    Bay Area, California
    2019 Prius Prime
    If you purchased a J2534 protocol dongle, the dongle will be able to plug into the OBD2 port for reading the codes;).
    Some members have had challenges either installing the software or having the dongle recognizing the software either due to installation challenges or the quality of the dongle:cool:.
    But it is set up to read the codes:).
    Good luck and keep us posted .
  7. andreimontreal
    347
    109
    28
    Montreal
    Should be here Fri or Sat. Will def update because of the whole brakes issue if you saw that.
