Mini VCI
Discussion in 'Generation 1 Prius Discussion' started by aswresm, Sep 16, 2014.
  1. aswresm
    aswresm Junior Member
    50
    2002 Prius
    I
    Will a mini VCI be able to detect a bad or weak battery cell module??
    Thanks
  2. aswresm
    50
    2002 Prius
    I
    Will it point you exactly to the weak cell module that needs to be changed??
  3. JC91006
    16,934
    8,644
    short answer is yes. But there may be others that are weak but not weak enough to detect via mini VCI
  4. Britprius
    Britprius Senior Member
    5,194
    1,922
    Herefordshire England
    If you run the VCI in test mode it will show up week modules by the more rapid rise and fall of the voltage against the others. It will also show the internal resistance of the modules. Recordings of the data can also be done while driving the car.
    John (Britprius)
    aswresm likes this.
  5. bwilson4web
    16,515
    The simple rule is any pair of modules, there are 19 pairs, that is off by 1.2V has a bad cell in those modules.
    Tbkilb01 and aswresm like this.
  6. miscrms
    miscrms Plug Envious Member
    2,079
    527
    Phoenix, AZ
    Does mini-VCI work on Gen 1?
    aswresm likes this.
  7. ericbecky
    ericbecky Hybrid Battery Hero
    4,451
    3,359
    Madison, Wisconsin
