Minimum voltage to retain presets?
Discussion in 'Gen 3 Prius Audio and Electronics' started by srivenkat, Sep 26, 2013.
  1. srivenkat
    srivenkat Active Member
    596
    93
    IL
    when the 12V is drained. Is 6V sufficient? If so, while supplying 6V, will the SKS still be running?
  2. vito.a
    vito.a Junior Member
    52
    17
    Tucson, AZ
    I see no one has answered you. I do not know the exact cutoff voltage for maintaining radio presets in the Prius. From past experience, it is usually something around 9+ volts. Remember, a 12V system is actually 13.2 V and with a running alternator is close to 14V.
    They sell an inexpensive kit that you can connect to the battery cables to maintain presets when changing batteries.
    If you give me some more background on your issue, I might be able to offer better advice.
