Minor loss of power on small hills.
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Austin Longenecker, May 3, 2020.
  1. Austin Longenecker
    123
    66
    Austin Tx
    Howdy y'all, I've recently noticed a small power loss in my 2010 Prius. It's not noticable if you're not familiar with the vehicle, I can still get to highway speeds as fast as you would expect. But here's my problem: when going up slight hills, the vehicle seems to take more effort than necessary. For example, the display will show the energy all the way in the PWR range when it would normally be in the regular zone. Cruise control on a flat surface acts normal, but up a slight gradient, the engine must work significantly harder than it use to. You can also hear the engine working harder than it use to.
    128,000 miles
    Brand new 12V
    EGR system replaced last year
    Coolant level steady
    Minor oil consumption, but I keep on top of that.
    Battery charges and discharges normally.
    No check engine light.
    No warnings.
    My driving habits are averaging at 5mph above the speed limit. Here in Texas, we have 60 to 75 speed limits around my area. It's much more noticeable at high speeds. At 70 MPH, the gas must floor it to keep speed up a slight hill that would normally have a minor impact on gas consumption. MPG stays at 40-50 on a flat surface.
    Anyone have any idea?
    SFO likes this.
  2. tankyuong
    tankyuong Senior Member
    1,555
    660
    Central MO
    Sounds normal
  3. Mendel Leisk
    38,718
    Is it noticeably more effort than in past?
  4. Austin Longenecker
    123
    66
    Austin Tx
    Correct. I've owned the vehicle for almost 3 years, it now takes noticeably more effort to travel the same hills than it use to. This began on a short road trip last week.
  5. pjksr02
    pjksr02 Active Member
    532
    225
    Connecticut
    You didn't inadvertently flip from "Normal" to "Eco" mode, did you? I once did that, and it perplexed me for days. But that shouldn't change the engine sounds (effort).
  6. Austin Longenecker
    123
    66
    Austin Tx
    Nope. I've checked that.
  7. bisco
    49,469
    did they do the whole egr circuit?
    get dr. prius and do a battery health check
    check the tires pressure
    clean the throttle body
    did you do the complete 120k service?
  8. Austin Longenecker
    123
    66
    Austin Tx
    Honestly at this point, I have no idea. They told me they did the whole circuit, but those guys did so much damage to the EGR I had to have it replaced AGAIN under warranty at a different location. Tire pressures are normal. I have not done the 120K yet, but plan to once my local shop reopens to full service, which should be very soon.
  9. Mendel Leisk
    38,718
    I'm coming around to the only way to do EGR is DIY, or you just don't know. It's so poorly documented, Toyota's no help. Too: the intake manifold is part of the EGR circuit: EGR gas feeds into the intake via a pipe on the right side (standing at front of engine bay), runs down a gallery, and into capillaries (one per port). The capillaries in particular can clog up badly. If they're not cleared all the EGR cleaning is for naught.
    @ArmyChief has posted some pretty nasty pics (at 156K miles), in a pdf, first post here:
    Intake manifold EGR ports clogged - PICS | PriusChat
    pjksr02 likes this.
  10. Austin Longenecker
    123
    66
    Austin Tx
    Unfortunately I learned that the hard way.if only I had the tools and resources to DIY. As a college student I don't have my own place to store equipment or work on my vehicle.
  11. ArmyChief
    ArmyChief Junior Member
    71
    49
    North Port, FL
    Sounds like a fuel delivery issue (caused by skewed sensor(s) or fuel pump) or restricted exhaust.
    do you have a scan tool ?
  12. Austin Longenecker
    123
    66
    Austin Tx
    I don't own one but have access to a cheap scan tool. I am unsure whether or not it is compatible with Dr. Prius.
  13. ArmyChief
    71
    49
    North Port, FL
    You won't need Dr. Prius. Regular Global scan tool will work for SOME diagnostics. You can monitor fuel trims at idle, 1500, 2500. Can also look at MAP (Manifold Absolute Pressure), BARO and determine engine vacuum.
    Can't guarantee anything (a good diagnostician should look at your vehicle with a OE-level scan tool). However, I can try to help if your interested in trying.
  14. Austin Longenecker
    123
    66
    Austin Tx
    I appreciate the offer. I'm going to take my car in for the state inspection plus some regular maintenance and see of they can determine anything while they're at it.
    ArmyChief likes this.
  15. Rebound
    Rebound Senior Member
    3,964
    2,613
    Portland, OR
    That’s one reason why we have MeetUps
    SFO, RMB and Raytheeagle like this.
