Misfire 1 & 4 when turning !
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Hamzeh, Dec 28, 2021.
  1. Hamzeh
    Hamzeh New Member
    Jordan
    Hello
    I have changed sparkplugs, coils ,clean injectors and ecm .And still misfiring !
    Please help .
  2. Hamzeh
    Hamzeh New Member
    Jordan
    Please help .. I dont know what I should do
  3. JC91006
    16,474
    8,393
    How is your coolant level? Does it drop?
    It potentially has a bad head gasket, which is a known problem in high mileage gen 3 Prius cars
  4. Hamzeh
    Hamzeh New Member
    Jordan
    I have checked it .. and I have cleaned and fix problem in intake valves .. but the problem isn't solved ☹
  5. PriusCamper
    PriusCamper Senior Member
    11,056
    4,499
    Pacific Northwest, USA
    Super low oil level will sometimes create symptoms like this... But seeing as you've done so much already to address this problem, I highly doubt you've over-looked being a couple quarts low on oil. :)
