Misfire Cylinder 4 P0304
Discussion in 'Gen 3 Prius Technical Discussion' started by Godzilla007, Oct 23, 2018.
  1. Godzilla007
    Godzilla007 Junior Member
    Phoenix
    So I bought this car for $1600 from a co worker. Told me the battery needed to be replaced (No problem I'll have it refurb) come to find out is shooting a P0304. So when I picked up the car the other night I noticed it took a while for it to pick up speed, I thought okay normal because of the weak battery. The next day I took it in to have the battery looked out. The tech said there are two code... P0304 and U029A. He looked under the hood and coolant was at Low, he also looked at the oil cap and dip stick no creamy substance just clean oil. Engine doesn't hesitate, no over heating, no smoke from tail pipe and engine sounds health.
    So the next day I decided to take a look at the oil again and I pulled out the dip stick and it was low on oil about 2 qts, after adding oil and topping off the coolant I drove it and it drove waaay better from the first day I drove it, it pick up speed much better. I looked at the service stickers and noticed that the oil should of been change about 7,000 miles ago! So I'm guessing that might explain why the coolant may of been low as well because it wasn't topped off. Took the car to my mechanic for a 2nd opinion and he says it drives good but that he does see the misfire. So the next step is to do a compression check and I really really hope compression is good and that the result of the misfire is a bad coil. I'm pretty sure that the spark plugs have not been changed at 100k miles so most likely they are the original and that might be contributing to the misfire. So if compression is good I'm going to have the spark plugs replaced and at the same time I'm going to have him clean the EGR and the EGR tube.
    With all this said what are the chances it's not the head gasket? Miles on car is 171k.
  2. Godzilla007
    Phoenix
    ***Update***
    All 4 cylinders are in good shape! Mechanic told me the car has it's original spark plugs, should of been changed 71k miles ago. I'm having him install 4 new ones and while we are at it having him clean the complete EGR. Going to replace the coil packs as well because they are the original ones as well.
  3. oasmith
    oasmith Junior Member
    42
    22
    Cleaning the EGR is labor intensive, but while he's in there, he should also clean the intake manifold, throttle body, and replace the PCV. All that is right in the same place.
    Raytheeagle likes this.
  4. Godzilla007
    Phoenix
    Well I already coughed up $280 for compression check, new spark plugs, and having him clean the complete EGR. I plan to clean the manifold my self and everything attached to it as well. PCV? Are you talking about replaced the PCV valve? Is the PCV valve something I can reach from the engine bay without talking all the crap off? Also plan on adding a Catch Can.
  5. oasmith
    42
    22
    Yeah, the PCV valve. It's super easy to get to with the intake manifold off, but i think it can be replaced without taking off the IM. It's a pretty cheap item, might as well replace it. You'll spend more on brake parts cleaner. I should have put the in the OCC. :(
  6. PriusCamper
    PriusCamper Senior Member
    12,056
    4,893
    Pacific Northwest, USA
    If you want to save some money, don't replace the coils, that's not a weak link in the misfire chain, the EGR is and because the EGR feeds into the intake manifold, that where more cleaning money should be spent.
  7. Raytheeagle
    Raytheeagle Senior Member
    11,263
    15,512
    Bay Area, California
    2019 Prius Prime
    Replaced ours the first time with the intake manifold on from below :eek:.
    Definitely a lot easier from above woth the intake manifold off;).
    And the pcv valve is only ~$7, so we’ll worth it(y).
    05PreeUs likes this.
  8. PriusCamper
    12,056
    4,893
    While this is what everyone has been saying for 40 years... How could such a simple thing like a PCV valve be prone to mechanical failure in such a clean burning fuel efficient vehicle? Is there even one documented instance anywhere on Prius chat or via mechanics where a Pius' engine problem was directly caused by a bad PCV valve? I mean why not just mail me your $7 and I'll buy lottery tickets and if I win I'll buy you a Tesla? Seems like the odds of that happening are higher than the odds of a Prius PCV valve failure...
  9. Raytheeagle
    11,263
    15,512
    2019 Prius Prime
    I see your speaking from vast experience here:rolleyes:.
    While the valve may rattle when you pull it out and shake it, does that mean it is functioning well? How do you measure it?
    All I can say is there is oil blow by, which comes from the PCV valve and if the valve is saturated in the vapors, I’d swap it out;).
    $7 well spent every 100 k miles or so(y).
    05PreeUs and mjoo like this.
  10. PriusCamper
    12,056
    4,893
    I'm not speaking from experience, I'm asking a question of those on here with more experience than I...
    And yes if there was visible discoloration maybe it'd be wise... But the only time I've ever seen PCV valve that wasn't perfectly clean and functional was in high school when I was working in an auto shop back in the 1980's and those were on really, really old cars with unbelievable sludge problems due to oil leaks and infrequent oil change.
  11. Raytheeagle
    11,263
    15,512
    2019 Prius Prime
    On the Gen3 the pcv valve is mounted relatively low, which does promote blow by moreso than on the Gen2 which is mounted on the top of the block. But we don’t have to be as careful when we change the PCV valve, we don’t run the risk of putting a hole in the cover;).
    Not sure what you mean by visible discoloring, as the valve isn’t visible at all and there is a hose that engulfs the discharge :cool:.
    Hope that helps (y).
    PriusCamper likes this.
  12. Godzilla007
    Phoenix
    Well I picked up the car last night and drive much better even with a weak Hybrid battery. Anyone have experience with Green Tec Auto battery's? Any good? I was going to have someone fix the bad/weak cells for $600 bucks but I might as well spend $400 more and get a battery that has been fully refurbished. Besides Green Tec Auto any other with good reputation that sell refurbished battery you recommend?
  13. 05PreeUs
    05PreeUs Senior Member
    1,097
    564
    MSP
    Oh boy....
    EGR will NOT cause a misfire due to needing a clean up, wow. Plugs then coils are THE two most likely causes, followed at a great distance by poor fuel atomization by the injectors.
  14. 05PreeUs
    1,097
    564
    MSP
    They rattle with good springs and broken ones (for those with springs), so that is a no-good test. The PCV valve is the single most UNDER maintained part on most cars, why? No profit in it. They will sell you air filters, brake flushes, cooling flushes, top engine cleaner, and on and on, but almost never a PCV valve. This lowly little part is single-handedly responsible for more oil consumption issues than is imaginable.
    The simple solution is to replace it according to the manufacturer's guidelines.
  15. PriusCamper
    12,056
    4,893
    Yea... if the misfire isn't related to a blown head gasket, that would be correct... But sometimes people spend way too much time replacing easy stuff before they do a full diagnosis.
  16. PriusCamper
    12,056
    4,893
    I saw more than one bad PCV valves in my auto mechanic days back in the 80's on beat up old oil sludge-coated engines, but cars these days run way cleaner and a PCV valve is such a simple basic mechanism that I haven't seen a bad one in decades. So I totally disagree that it is an "UNDER maintained part on most cars." In my book, it's most unnecessarily replaced part because it is so cheap.
    Of course I'm always willing to learn... If you can show documentation of lots of Prius diagnosed with a bad PCV valve I'd love to learn more.
  17. 05PreeUs
    1,097
    564
    MSP
    School in session. How many modern vehicles have you diagnosed with a high oil consumption complaint? I've done HUNDREDS and feel absolutely zero need to document it on this board or anywhere else.
    You are welcome to attend the school of hard knocks yourself, if inclined, but those that know because they have done will continue to offer their considered advice.
  18. Mendel Leisk
    40,574
    The US maintenance schedule is outlined in a booklet called "Warranty and Maintenance Guide". If you can't find that, you can download a pdf at Toyota Tech Info (just google that), in the "manuals" tab. The spark plugs were not due for replacement at 100K miles, it's 120K miles (or 12 years, whichever comes first). Still overdue obviously, but don't rely on your mechanic to know the maintenance schedule in-and-out, go back to the source.
    Don't guess, just top it up to the full line, and keep an eye on it. I'd think if there's a head gasket problem it'll drop pretty fast.
    I'd second cleaning the EGR and Intake Manifold, and installing an Oil Catch Can. EGR clogging and the PCV system dumping oil into the intake manifold are a tag-team that enable each other, and once the EGR is clogged your engine temps go up, a lot.
    It's possible for a mechanic to do all this stuff, but it is labour intensive, which means either he'll cut corners, or it will cost you a lot. Your best bet for all of this is to DIY. Some threads:
    EGR & Intake Manifold Clean Results | PriusChat
    Oil Catch Can, Eliminate that knock! | PriusChat
    And for invaluable videos, by @NutzAboutBolts :
    Nutz About Bolts Prius Maintenance Videos | PriusChat
  19. PriusCamper
    12,056
    4,893
    Yes, I love school... Learning is my greatest obsession! Can you send a link / explain how excessive oil consumption symptoms are PCV valve related? Especially as relates to Atkinson combustion cycle on a Prius when PCV valve shows no discoloration or malfunction when you inspect it?
    Also is Atkinson more prone or less prone to PCV valve issues?
    You don't have to spend much time on this... Just please point me in the direction of learning more?
    #19 PriusCamper, Oct 30, 2018
  20. 05PreeUs
    1,097
    564
    MSP
    Absolutely...
    NOT.
    Educate yourself.
    I will not argue with those who insist that what you read from a g00gle search or watched on yourtoobe is accurate. Much of what separates the great mechanics from the parts changers is experience and the willingness to learn.
