Misfire due to oil in combustion chamber - causes, replace/repair engine?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by rjgale, Sep 5, 2014.
  1. rjgale
    rjgale Junior Member
    Maryland
    CEL came on in July at 165K miles, though there weren't any noticeable issues with performance. I took it to the dealership and they found P0300 and P0304 misfire codes. They replaced the spark plugs, and everything seemed fine for over a month.
    Note: They said I still had original spark plugs, which I refuted. I had 100K service at this dealership, which included "Replace regular spark plugs". I found out later from them that because the Prius doesn't have "regular" spark plugs, they didn't replace them during this service and didn't bother to tell me.
    CEL came back on last week around 168K miles. Still no noticeable symptoms. I took it back to the dealership today, they found misfire codes again, and initially recommended a tear down to diagnose for $1672. I pushed for further inspection and they found that there is oil bypassing the piston rings and getting into the combustion chamber, which is fouling the spark plugs. They said they would need to tear down the engine to repair it, and that it would be cheaper to replace with a used engine.
    What could cause this issue? Could it be related to not replacing the spark plugs or anything they did in the past? Is it possible that this would be normal wear and tear on the engine at 168K miles? I did drive the car for its first 2 years/60K making deliveries, starting and stopping on short trips often, if that makes a difference. Otherwise, normal driving conditions.
    Would it really be more expensive to repair than to replace? Any advice is very much appreciated.
  2. Patrick Wong
    18,200
    6,493
    What is most likely to cause this issue is the lack of engine oil changes at the proper interval (5K miles), using a poor quality of engine oil, or allowing the engine oil level to drop below the lower dimple on the oil dipstick.
    It definitely would be much more expensive to repair the engine vs. buying a used engine for $400 and swapping the original engine out, labor would probably cost ~$1,500.
  3. JC91006
    16,674
    8,519
    This dealer is probably incompetent. Bring it to another dealer.
    If you know how to remove the spark plugs, take a look at them. At 3000 miles, there shouldn't be much wear on them. They would have to be severely fouled to cause a misfire code.
    You probably just need to clean out the injectors and make sure they are working properly
  4. valde3
    valde3 Senior Member
    2,002
    746
    Finland
    JC91006 Is probably right first make sure that what dealer told you is true.
    Only if you are thinking of replacing or tearing down engine:
    If only problem of the engine is the oil getting past piston rings then first I would test if problem would go away by cleaning piston ring grooves and oil return holes. You can partially clean them by pouring solvent or diesel into cylinders from spark plug holes. And leaving it for day or two. This has worked on some Toyota engines that have used lots of oil. You have do oil change afterword since cleaner that gets through gets into your oil. Also you have to get rid of cleaner that is left in the cylinders. Normally easiest option is to crank engine without spark plugs but with prius you may need to do something a bit differentially.
    If the engine has run with almost no oil then only real repair is to replace engine.
    #4 valde3, Sep 5, 2014
  5. rjgale
    Maryland
    Thanks for the quick responses!
    Patrick - If they are right about the diagnosis...
    Most of the oil changes were done at the 5,000-5,500 interval, and the most it went was about 6,500 once. Would going just a little longer than the 5K interval have been enough to do it?
    The oil changes were with conventional oil and almost all done at dealerships. Would a dealership use such a low quality of oil that it might cause this major of an issue?
    With regular oil changes and no leaks, how likely is it that the oil would have dropped too low to cause this?
    JC - This isn't the first issue I've had with the service department, so I wouldn't be surprised if it's just incompetence. Are you suggesting that they might be wrong altogether about the issue with the piston rings, and that there couldn't possibly be enough oil getting in to foul the spark plugs this soon? I think I'll take your advice and take it to another dealer to ask them to look at the injectors.
  6. JC91006
    16,674
    8,519
    At 165k miles, many things could go wrong with the car engine. However the Prius engine does hold up quite well so unless it's been neglected, it shouldn't have severe problems that require replacement this early on.
    Many people have burning oil issues at your mileage. Make sure your oil level is not low, that "might" be the reason for your problems but it's something you should keep an eye on. My cars burn up to 1 qt of oil in 1500 miles or less. So a car that only holds about 3.75 quarts, at 5500 miles, you'll be pretty near empty with your engine oil.
    You can try dumping a bottle or 2 of Techron fuel injector cleaner into your fuel and see if things will improve after a couple tanks. This is probably what the dealer would call an "injector cleaning".
  7. rjgale
    Maryland
    Dealer gave me quotes on replacing the engine. $2,300 for labor, and $2,500 for an engine with 25K or $1,600 for an engine with 75K. So I'll take it somewhere else if it looks like it does need replacement. Also, he said they needed to put the car back together still, so I asked them to take pictures of the fouled spark plugs. Then he back tracked and said he wasn't sure if they were still out, and that I would only see some oil on them but no carbon build up. I'll post the pics for feedback if they take any.
    If I do use the fuel injector cleaner and continue to drive the car, how much risk is there in continuing to drive it with the misfires but no noticeable symptoms? How long would it take for the cleaner to work, and could it possibly stop the misfires and clear the CEL?
  8. JC91006
    16,674
    8,519
    I would check to make sure the injectors are all working properly, this dealer should be able to do it with it taken partially apart. You really shouldn't drive a car with a misfire, it could do more damage. Does the check engine light flash or remain lit? They say it's safe to drive a car with a lit check engine but not safe to drive a car with a flashing check engine light
  9. rjgale
    Maryland
    The check engine light is lit, but it isn't flashing. I do find it odd that I haven't noticed any symptoms, but maybe it's misfiring at a rate just high enough to meet the threshold.
    #9 rjgale, Sep 5, 2014
  10. Patrick Wong
    18,200
    6,493
    Your oil change intervals are OK. The implication behind your question above is that you do not periodically check the engine oil level. If this is true, then it is highly likely that your engine has been consuming some oil, the oil level dropped below the minimum acceptable, and engine damage was caused by insufficient lubrication.
    At this point, you need to see what the spark plugs look like. If your car ran OK for 3K miles after the plugs were changed, then I doubt that fuel injectors are the issue.
  11. rjgale
    Maryland
    I hadn't been checking the oil level because I didn't think I needed to with regular oil changes.
    Is low oil a more likely cause than the spark plugs not being replaced until 165K, poor workmanship, or some other maintenance that the dealership missed?
    If I do replace the engine, is it worth it to get one that's remanufactured vs. used, and what about the difference between a dealership vs independent shop in terms of cost, reliability, and warranties? I'm worried about finding a shop that I can trust, and I don't want to pay $3,900-$4,800 for a used engine at the dealership.
  12. Patrick Wong
    18,200
    6,493
    A low engine oil level is the most likely reason for the engine damage that your car has, assuming that the dealer tech's description of the problem as posted by you is valid and that the issue is spark plug fouling due to excessive engine oil in the combustion chambers resulting from abnormal cylinder/piston wear. You now know that you must check your engine oil level and all other engine compartment fluids periodically and I hope you will remember this when you buy your next car, whatever it may be, and no matter how new or old that car is.
    Even if your car has a perfect engine, how do you know that the engine oil level is correct after the lowest-paid individual in the service department changed the oil - if you don't bother to check the oil level yourself? And since we live in an imperfect world, you need to realize that engines typically will consume some oil especially after you log 100K+ miles, not to mention whether or not the engine oil was properly filled by the mechanic.
    Worn spark plugs would cause engine misfire symptoms but would not cause the severe engine damage that you have described, at least not at 165K miles which is only 45K miles past the normal schedule and 15K miles past the schedule for California vehicles.
    A remanufactured engine will probably cost more than a new engine block. You can buy a new engine block for $1,335 plus shipping here:
    2007 Toyota Prius Parts - AutoNation Toyota Gulf Freeway Parts
    However a substantial labor charge is required to remove the old engine, transplant the cylinder head and intake/exhaust manifolds from the old engine to the new engine block, and there will be a charge to replace parts like the engine coolant pump, thermostat, serpentine drive belt, idler pulley, timing chain, cylinder head gasket, valve cover gasket, oil pan gasket, oil pump front cover assembly, PCV valve, intake and exhaust manifold gaskets etc. with new parts. Some of those parts are consumables and with the others, it makes no sense to reuse old parts with 165K miles logged. Further, when the cylinder head is removed, maybe the mechanic will determine that the head needs to be rebuilt, which will require a substantial machine shop charge, maybe another $1K.
    Also consider the market value of your 2007 Prius and think about whether it makes sense to spend $5K+ on a new or remanufactured engine plus the associated labor charge.
    If you can find a competent independent trained on Toyota hybrids or at least specializing in Toyota vehicles, with access to Toyota Techstream or equivalent and the factory repair manual info, that would constitute a reasonable dealer service alternative. Maybe you can get a used engine installed for $2K - $2.5K total. Obviously you bear the risk regarding how long the used engine will last but if you get an engine with low miles that should be a reasonable risk to assume - unless the prior owner thought like you that the engine oil level could be ignored.
    #12 Patrick Wong, Sep 6, 2014
  13. rjgale
    Maryland
    Update: After getting two quotes of $4,200-$5,200 to replace with a used engine at independent shops, I took the car to an independent shop for a second opinion. After three days of diagnostics, which they agreed to only charge 3 hours of labor for, they believe that the ignition coils were the cause of the issue. They didn't find any evidence of oil bypassing the piston rings and entering the combustion chamber like the dealership had described, which I was glad to hear, but it makes me wonder whether the dealership was incompetent or dishonest.
    Even though the spark plugs had been replaced 3K miles ago, they said that the issue caused them to need to be replaced again. For replacement of the ignition coils and spark plugs plus diagnosis the total cost is $1,525. Better than $4K+ to replace with a used engine, but still seems high. I'm picking up the car this afternoon, so I'll have the breakdown of the cost later. I tried searching for but had trouble finding the typical cost to replace spark plugs and ignition coils. How much should that normally be for parts and labor?
    Also, shouldn't it have been easier to find that the issue was caused by the ignition coils? It seems like that's a common cause of misfiring.
  14. JC91006
    16,674
    8,519
    Spark plugs $40 for 4 online (not sure why they needed to change this again)
    Ignition coils - $77 each online (all 4 are bad?)
    Parts will be $350
    Make sure you get a good warranty on the $1500 repair. Make sure that'll fix your problem.
  15. M in KC
    M in KC Active Member
    358
    106
    KC, MO
    Has any garage performed a cylinder leak down test on the ICE to positively identify failed or failing ICE components due to oil starvation or other mechanical defect? I don't understand how one shop can indicate one symptom and the other something completely different unless one or the other has done more sophisticated diagnostic testing. $1525 for 4 plugs and 4 coils, is better than $4k but all the same, WOW! I'm not sure what your DIY skill sets are but if in fact the plugs and the coils are your issues you can teach yourself a $1200 lesson pretty quickly. There are plenty of How-To's on here and Youtube for inspiration. Good luck!
  16. JC91006
    16,674
    8,519
    at $1500, I just feel there has to be more to it. I can't imagine a 1 hour job being $1200 in labor charges
  17. rjgale
    Maryland
    They said the wear on the spark plugs was enough to require replacement and that since 3 of the coils were causing misfires, they replaced all 4 since the 4th would wear out soon anyway.
    They said that 3 techs and the owner were working to diagnose the problem and they didn't charge for about $1,500 worth of additional labor for diagnosis. Here's what they list for diagnostics: remove and examine spark plugs, check fuel trim, relieve pressure from fuel system and test a fuel sample, remove MAF sensor and test, remove manifold absolute pressure sensor and test, check positive crankcase ventilation system.
    Here's the breakdown of the cost. It's a lot, but I'm not a DIY guy, so I wouldn't trust myself not to damage the car doing the work on my own. Also, parts and labor are under warranty for 2 years/24K miles.
    Parts - $804
    $674 - 4 ignition coils x $168.50
    $79 - 4 spark plugs x $19.75
    $51 - job supplies
    Labor - $638
    $351 - 3 hours for diagnostic
    $287 - about 2.5 hours for repairs
    Environmental compliance - $35
    Tax - $48
  18. bisco
    51,155
    if it fixes the problem, i think you did well. all the best!(y)
  19. PriusGuy32
    1,417
    513
    Harrison Township, Michigan
    I am going to say it.... I know all that matters is you have your car back and it runs fine now and blah blah blah but, WHAT THE $*!)& did you just pay ?!?! :eek:
    That repair shop charged you $1,525 to replace the iridium spark plugs and your ignition coils!?! Seriously?
    That can be done by a basic DIY'er for under $200. I suppose I come from a different world, but even for testing fuel pressure and other small things, $1,525 is on the insane end of high. I wouldn't ever return to that shop, even if Jesus was the mechanic himself :LOL: I also wouldn't tell anybody - your neighbors, in-laws, boss/co-workers, or friends what you just paid for basically a full modern day tune-up, unless you enjoy being ridiculed.
    Of course, I realize not as bad as the highway robbery the dealership was trying to attempt...but still. I had to say what I did. Happy your car is fixed for less than the $4000 or whatever the dealership quoted, but damn. o_O
  20. dolj
    dolj Senior Member
    8,217
    4,187
    Wellington, New Zealand
    Now I'm going to say it.
    Nooooo, they charged $1091 (plus env chrg and tax) to fix the problem. They charged $351 to find out what to fix. They also threw in $1500 of diagnostic time as a goodwill gesture and had 4 of their guys (including the owner) looking at the problem to come up with their diagnosis.
    It's all good and well to say :
    but unless you know what to fix you're up s#!t creek without a paddle. In my experience you pay your professional for their knowledge and skill. If I had that myself I could save a whole lot, but I don't so I pay someone who does. BTW, seeing as the basic parts are $305 (by JC's reckoning and $753 by the shop's), I don't see how you arrive at $200.
    There is no shame or ridicule in paying someone for their knowledge if you don't possess the skills or knowledge yourself.
    The only thing that I agree with you is that it seems that it took them an insane amount of time to reach their diagnosis. It seems that the repair shop agrees by throwing in $1500 of diagnosis for free.
    I also agree with JC, there is probably more to it that it seems on the face of it.
    Just my $0.02 worth.
    #20 dolj, Sep 12, 2014
