Misfire, white smoke from exhaust, lose coolant, P148f +?
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by Mohammad Seyyednezhad, Mar 10, 2019.
  1. Mohammad Seyyednezhad
    Mohammad Seyyednezhad Junior Member
    Norway
    I've solved the problem. The Prius uses a system to heat the coolant quickly when it is cold. If this system works poorly it boils in the coolant then it increases the pressure in the cooling system. The symptoms are similar to poor cylinder head.
  2. mikefocke
    3,701
    1,649
    Sanford, NC
    Can you be more specific about what part you found faulty and how you fixed it please.
  3. Mendel Leisk
    38,728
    Any lights on dash, say check engine light? Also, how many miles on it?
  4. Mohammad Seyyednezhad
    Norway
    2014 prius v 410000 km , Ijust cut the system . I took out the hose from the egr cooler directly connected to the heater core radiator in the ac.
  5. Mohammad Seyyednezhad
    Norway
    looks like the error is back. Replaced water pump and thermostat, egr valve and egr cooler replaced old injectors. The new water pump (Asian) behaves differently than the old one. It appears that when the engine gets hot, the coolant boils.
  6. Lesk_The_Glut
    Lesk_The_Glut Junior Member
    Bakersfield, CA
    What was your ultimate fix?
  7. johnHRP
    johnHRP Active Member
    417
    133
    tally, fl
    Not EGR coolar but hear exchanger after the catalytic converter
  8. ChapmanF
    15,630
    That item includes a thermostat that redirects the exhaust flow after it's warm enough, so perhaps an issue with that could cause problems.
    The thing about this thread, though, is that the original poster was last heard from in March of 2019 ... and that post was to say that the post #1 idea about what fixed the problem had not, in fact, fixed it.
  9. Mohammad Seyyednezhad
    Norway
    It was head gasket that failed. If boiling in the coolant then do not spend time on other things go straight on it.
  10. Tim Jones
    Tim Jones Senior Member
    1,706
    553
    SE Texas
    2011 Nissan LEAF
    HG again.... thanks toy
