1. polophonic
    polophonic Junior Member
    UK
    Greetings all, I have learnt a huge amount from this forum and in doing so saved many £££$$$. But I now think I have a problem that has stumped me. So if anyone is able to help then I would be very very grateful.
    I have a persistent #1 misfire - P0301 - with also intermittent P0300,/3/4. Having searched the threads, I have done the following with no effect:
    1 - replaced spark plugs (all plugs looked good, there was some corrosion around top of #1 seems the usual issue of water/oil ingress there)
    2 - replaced coil pack #1,
    3 - moved coil packs between cylinders to see if the problem moves
    4 - replaced fuel injectors
    5 - tested compression on all cylinders, they are all a little under 125 (after repeating the test)
    The particular symptoms I experience, is that the car runs smoothly with no load (e.g. in park put foot on gas pedal), but the moment its charges up the hybrid battery, very loud clunking and shaking starts. Driving can produce a blinking engine management light.
    Could this a be a bearings, rods, bottom end problem, and if so what would be my next steps for diagnosis?
    Many thanks!
  2. Tombukt2
    Tombukt2 Senior Member
    12,015
    2,124
    Durham NC
    No coolant disappearing You've ruled out a head gasket You've replaced the coil that you thought could be the offending one which I'm guessing is cylinder one and then you moved the cylinder one coil to another cylinder and put that cylinder in one and nothing changed we're still misfiring on cylinder one? And all your compression is about 125 which isn't too awfully horrible for a near 20-year-old engine I don't think.
    polophonic likes this.
  3. mr_guy_mann
    mr_guy_mann Senior Member
    3,939
    1,900
    NJ-USA
    Typically, nothing in the cylinder block is going to be variable. Either it works, or it's broken.
    While it is possible to have something like a broken valve spring (that might be RPM sensitive), most top end mechanical faults are constant (always broken). Not load sensitive.
    You have done fairly comprehensive "swap-tronics" to rule out the most common faults.
    Unfortunately the next level of diagnostics requires some sophisticated equipment like digital oscilloscopes, and the knowledge to use them (or interpret advanced scantool data , vacuum gauge readings, testing ignition coil output, etc.)
    Brian1954 and polophonic like this.
  4. polophonic
    UK
    Many thanks for reply - yep, that about covers it and what I have concluded. Looks like I have a bit more complex problem determination to get to grips with.
  5. polophonic
    UK
    Many thanks - I will see if costs of kit makes it sensible to go that route, or whether I should continue to try and find a competent and reasonably priced garage to take a look.
    Brian1954 likes this.
  6. polophonic
    UK
  7. pasadena_commut
    pasadena_commut Senior Member
    2,218
    661
    Southern California
    Really, no P0302? Ever? If that's really the case it sounds like a timing problem of some sort, which hits 1 a lot, 2 never, and 3,4 intermittently. Hard to imagine any general problem (like fuel pressure or a MAF issue) with that sort of specificity.
  8. polophonic
    UK
    That's a very good point. I will clear codes and check again. Other thing to note is that this problem emerged over the course of a drive. I first started to notice some hesitation driving up a hill. This then increased in severity over about 5 minutes with the end result being flashing engine light and very loud banging/shaking when stationary and charging the traction battery.
  9. Tombukt2
    12,015
    2,124
    Durham NC
    Sounds like in this generation to you need to do a serious testing on the four cylinder internals and see that you're not actually putting the fire out with a small head gasket leak or something sounds awful lot like you've got that tradition going on and this is an engine that can be repaired on. 1NZ.
  10. polophonic
    UK
    An update: after clearing all codes, I now have misfires on all cylinders *except* #1! So the problem cylinder is now the cylinder that seems to be behaving. I will do more coil swaps and see if that changes anything (it didn't last time, but who knows).
  11. Brian1954
    Brian1954 Senior Member
    1,703
    664
    South Central PA, USA
    It is time to have a professional mechanic take a look at the engine. To me, it sounds like you may have a major problem inside the engine.
