Misfiring issue
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by ozymandias, Feb 11, 2014.
  1. ozymandias
    ozymandias Junior Member
    83
    Virginia
    My Prius started shaking pretty bad when the ICE is running. This morning I got the codes read and it came as Cylinder #1 misfire. I figured the coil pack is going bad (as is known to happen) so I swapped #1 and #2. The misfiring actually got better for about 30 minutes, but it finally happened and the CEL flashed again. So I took it to get the code read but he said the only code is still #1 misfire. Perhaps the ignition coil is OK then? I bought a new spark plug, maybe the plug has gone bad. The plugs only have 45k miles on them. I'll swap it out and see what happens. Any other suggestions on what I should do to diagnose the issue? It seems to be slowly getting better...this afternoon it was much better than this morning but still shaking sporadically.
    Thanks!
  2. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,338
    Wilmington, NC
    Any water around the spark plugs? There are several threads on this topic.
  3. edthefox5
    edthefox5 Senior Member
    10,096
    4,806
    Clearwater, Florida
    Water and alot of people have spilled oil while filling the oil up right there and it leaked into the sparkplug well.
    There's a TSB to replace the foam water dam right above the cylinder head to prevent water from gushing over and under the dam when it rains and drip on the cylinder head gets into the wells and shorts the plug out to ground.
    search:
    lusciousgarage.com repair blogs. They mention it.
  4. ozymandias
    83
    Virginia
    No, I pulled the coil and stuck a paper towel down in there...it's dry. A small amount of oil but that is it. I guess I'll try replacing the plug.
  5. ozymandias
    83
    Virginia
    Looks like it can be the injector too...so I guess I have more troubleshooting to do.
  6. Patrick Wong
    18,200
    6,474
    Each time that you make a change, do you also disconnect the 12V battery for a few minutes, to clear the DTC logged by the engine ECU?
    I agree that a misfire may be caused by either an ignition or a fuel injection issue so you need to investigate both.
  7. ozymandias
    83
    Virginia
    No, I had assumed if the misfire moved to #2 there would be codes for #1 and #2 both. I will disconnect the battery before starting the car next time. Thanks
  8. Patrick Wong
    18,200
    6,474
    It also may take some time for the DTC to log. For example, some DTC are not logged until the problem persists for two engine starts. So it would be good to clear the DTC so that you'll know when the new DTC is logged (based upon seeing the check engine light appear.)
  9. nikmaster
    nikmaster New Member
    Las Vegas, Nevada
    First start with replacing all spark plugs, not just one. We had many cases with knocking badly engines, even not starting -caused by bad spark plug. Misfire could be shown on any Cylinder, but does not mean that the wrong one. Spark plug is recommended to be replaced at 120K miles. Don't put fancy sparkplugs, just the original.
    edthefox5 likes this.
  10. engerysaver
    engerysaver Real Senior Member
    426
    130
    Tyler, Texas ; USA
    Maybe it is a bad tank of gas!! :(
    Try some Berryman B-12 Chemtool!!:)
  11. EKIM
    EKIM Junior Member
    61
    Escondido, CA
    I've got the same problem. Same cylinder. It's ugly. The plug was uglier when I pulled it. About 5K miles on it as far as I can tell from previous service record.
    I replaced the plugs but I still get the misfire. I haven't tried swapping the coils yet.
    I'm concerned those are metal deposits on my plug.
    The other plugs were perfect:
  12. Patrick Wong
    18,200
    6,474
    I think that the excessive black deposits are from engine oil leaking into that cylinder. A cylinder compression test or leak down test would probably show very poor results in that cylinder.
  13. Easy Rider
    Easy Rider Active Member
    982
    210
    N. Central Florida
    Yes, if it feels and smells like oil.
    Could be just running VERY rich from a stuck injector too.
    In that case, the plug tip would probably smell more like gas than oil.
  14. PriusGuy32
    1,417
    510
    Harrison Township, Michigan
    Sweet tap dancing Jesus :eek:
    Ive seen fouled spark plugs in my watercraft, my atv, old old abused engines with carburetors, but never seen one that bad on even a very badly abused modern EFI engine!
  15. EKIM
    EKIM Junior Member
    61
    Escondido, CA
    I'm double/cross-posting here (I have more info under the "intermittent CEL" thread title.
    But here's another #1 plug from a 2008 Prius. This one has 340K miles on it.
    Cyl 2 wasn't a ton better, but at least it had all of it's insulator porcelain on it.
  16. tomw
    tomw Junior Member
    28
    Milton, ON, Canada
    I had a similar issue on my 2007. I just cleaned the injectors with some carb cleaner and the issue went away.
  17. ozymandias
    83
    Virginia
    I guess I should follow up. I put in Lucas injector cleaner when I first went to the auto parts store to pull codes. A day after my last post, the problem went away and hasn't come back. So I guess an injector was clogged.
  18. ursle
    ursle Gas miser
    1,049
    192
    NH
    I just checked the database and those are Sigourney Weavers fingerprints, that's an alien baby, named... E10
