1. PriusNewbie32
    PriusNewbie32 Junior Member
    TN
    Prius has been misfiring. EGR pipe cleaned, spark plugs changed, ignition coil changed. My mechanic thinks it's contaminated gas. He suggests running it out. As it misfires once I hit 15, and not while idling, I thought about just turning on maintenance mode and idling the tank out. How long can I safely leave maintenance mode on? Any idea how long it'll take to idle out half a tank?
    51,996
    did you do the whole egr circuit? throttle body? how many miles on her?
    i hope its not the headgasket
    #2 bisco, Jul 27, 2019
  3. Groundpounder17
    104
    77
    AR
    The all too common high mileage gen 3 misfire. I hope your mechanic is right but out of all the misfires I’ve read about I have yet to read about one due to contaminated gas. Did you clean the complete egr system and did this happen before or after the misfiring began?
  4. PriusNewbie32
    TN
    I cleaned the pipe and only cleaned the EGR valve as far as I could get the cleaning straw in. I didn't take it off. It started after we cleaned it as soon as we put it back together.
  5. PriusNewbie32
    TN
  6. Groundpounder17
    104
    77
    AR
    The egr cooler needs cleaning
    Mendel Leisk, Raytheeagle and bisco like this.
  7. bisco
    51,996
    NutzAboutBolts and Raytheeagle like this.
  8. PriusNewbie32
    TN
    Can I siphon gas out? I don't want to jump start the fuel pump.
  9. bisco
    51,996
    i don't see why not
  10. PriusNewbie32
    TN
  11. Mendel Leisk
    41,514
    You need to clean EVERYTHING between the EGR connection to the exhaust, through to the intake ports, and install an oil catch can.
    It's a design fail.
    Per @bisco : how many miles?
    Watch all the relevant @NutzAboutBolts videos, pinned at top of 3rd gen maintenance forum.
    Do that first, leave the gas siphoning for later.
    NutzAboutBolts, mjoo and Raytheeagle like this.
