Missing Brake Fluid Cap
Discussion in 'Newbie Forum' started by donaldrsquires, Oct 6, 2018.
  1. donaldrsquires
    donaldrsquires New Member
    St. Louis
    Hello all,
    So I went to get an oil change today as well as a state inspection and the mechanic mentioned that I'm missing the Master Cylinder Cap (which seems to be the cap on the brake fluid reservoir). I took a look and it is definitely missing somehow... Obviously, it's terrible to be driving around without this cap and I'm not sure how it went missing and the mechanic seemed to have no idea where I could get another one. I've tried all the local places and online but can't seem to find just a replacement cap. I've covered it up in the mean time but am really struggling to find a replacement. Any suggestions?
  2. Skibob
    Skibob Senior Member
    2,912
    1,496
    Northern California
    The Toyota dealer cant get you one?
  3. PriusCamper
    PriusCamper Senior Member
    11,106
    4,520
    Pacific Northwest, USA
    Find a junk yard with Prius... Preferably a yard that allows you to pull your own parts. It's good to know where these places are for future odds and ends that break or go missing.
    49,511
    welcome! eBay
  5. Starship16
    Starship16 Senior Member
    1,348
    1,453
    Beach Christmas
    Duplicate post
    #5 Starship16, Oct 7, 2018
  6. Starship16
    1,348
    1,453
    Beach Christmas
    Duplicate post
    #6 Starship16, Oct 7, 2018
    GrGramps likes this.
  7. Starship16
    1,348
    1,453
    Beach Christmas
    See if you can find it on Toyotapartsdeal.com
  8. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,175
    2,213
    Taylors, SC
    The master cylinder cap is pretty much universal for Toyota for 20+ years.
    The part # is 47230-12040.
    Skibob and PriusCamper like this.
  9. Usle
    Usle Active Member
    317
    139
    Me
    2018 Prius Prime
    A little history, where do you get your oil changed and when was the last one, obviously the technician left it off, as brake fluid is suspectable to air, and absorbes air, time to flush all the fluid and start over, the dealer that changes your oil should work with you, if not do it anyway, then find a more trustworthy dealer.
  10. PriusCamper
    11,106
    4,520
    By susceptible to the air you mean it absorbs moisture and you don't want water in your brake lines? Or do you mean break fluid can deteriorate due to oxidization?
    Georgina Rudkus likes this.
  11. Mendel Leisk
    38,738
    Put something on in the interim, say plastic and a rubber band? Maybe punch a single pin hole in the plastic so it's not completely air-tight.
  12. Elektroingenieur
    2,515
    3,260
    Three Touring
    That one is used on many models, but not on any Prius cars. The parts catalog for a 2010 Prius, in Figure 47-02, Brake Master Cylinder, gives two part numbers: 47230-11010 (plain cap) or 47230-20140 (with valve), depending on production date.
    Skibob and Mendel Leisk like this.
  13. Georgina Rudkus
    3,175
    2,213
    Taylors, SC
    My original number came from the one on my 2012 Prius v.
  14. Skibob
    2,912
    1,496
    Northern California
    I would be more worried about dirt getting into the master cylinder than anything else. Moisture can be purged thru a good fluid flush. Dirt is another thing. It can get stuck at the seals and damage them.
