Missing gauges
Discussion in 'Gen 5 Prius Main Forum' started by RafaJPG, Mar 7, 2024.
  1. RafaJPG
    RafaJPG New Member
    La Paz, Baja California Sur, Mexico
    2024 Prius
    I really miss Engine/Trans Temperature and Oils Pressure, anyone has tried an OBS2 reader + Torque App on the screen?, if you, please share...
    TGrracie likes this.
  2. RandyPete
    RandyPete Active Member
    409
    169
    Santa Margarita, CA, USA
    2024 Prius Prime
    XSE
    Different beast. You might be more interested in inverter coolant temp, M1 stator temp, M2 stator temp and traction battery cell state of charge (cell balance) as you experience more PHEV use.
    Jeff606 and TGrracie like this.
  3. Paul Gregory
    Paul Gregory Senior Member
    2,247
    595
    Alberta
    2024 Prius Prime
    XSE
    What would be the best OBD app to use with a Bluetooth OBD dongle?
  4. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,513
    2,503
    Taylors, SC
    I use the Scangauge 2. It's set up to read 12 volt battery voltage, radiator coolant temperature, inverter coolant temperature and high voltage battery temperature.
  5. Trollbait
    12,691
    The new Scangauge III is spiffy.
  6. Mendel Leisk
    41,934
    I used to use a Scangauge II, but found it was causing system errors, possibly due to constantly weighing on the OBD port. On the other hand, others have had no such problems.
    Yeah, used to be every car had a coolant gauge, very handy. Frustrating that Toyota nixed that on Prius. How about their other vehicles, same story??
  7. Leadfoot J. McCoalroller
    8,150
    7,654
    Pennsylvania
    2018 Prius c
    You can add gauges to get a few different readouts, but you won't get oil pressure as the car does not have a pressure sending unit.
    All it knows is whether the emergency low pressure switch is open or closed.
    You could add a sending unit and combine the readout with CAN-derived data on a 3rd party display, it's been done.
  8. Georgina Rudkus
    3,513
    2,503
    Taylors, SC
    A mechanical oil pressure gauge can be added with a tube to the M18x1.5 oil filter adapter plug. This is the same type with a 10mm hex socket used for the transaxle drain and fill.
