missing item in trunk
Discussion in 'Generation 1 Prius Discussion' started by b2kon, May 15, 2008.
  1. b2kon
    b2kon New Member
    2001 Prius
    Hello all!
    i just bought a classic and there is this styrofoam box with cut-outs on the right side of the trunk.
    the only thing there is the heavy steel ring with a threaded bolt.
    there is a vacant rectangular space.
    What are supposed to be in these slots and for what purpose.
    Many thanks to all!
    Tony
  2. ChapmanF
    15,496
    Hi Tony,
    What you've got there is the towing eye. You should be able to tighten it into the threaded hole in the driver's end of the front bumper, in case you ever need to be pulled out of a ditch. It's a good idea to make sure you really can start the threads in that hole, because mine got so rusty that I can't, making the tow eye useless. After cleaning up the threaded hole, people talk about giving it a heavy coat of grease and popping a rubber stopper in.
    I've been trying to figure out what exact thread is used there, to get a tap for cleaning it up. I think it's M21x2.0 or M22x2.0 (I'm certain of the 2.0, it's just the diameter I'm not sure of, and none of my local hardwares or machine shops has a thread gauge that size to make sure).
    As for the rectangular cavity: in some countries (European?) the car is required to come with a warning reflector for breakdowns; the end would go in that cavity, and it would be secured upright with the little strap you should see near the wheel well. In the US we don't get the reflector, but we still have the rectangular hole and the strap.
    The previous owner of mine apparently discovered that a 300W TrippLite inverter fit that cavity perfectly, and they left it for me. :D
    -Chap
  3. b2kon
    b2kon New Member
    2001 Prius
    Thank you so much Chap!
    I will check the threaded hole, grease it and plug it.
    -Tony
  4. Patrick Wong
    18,200
    6,472
    Hi Tony,
    If I correctly recall, the towing eye may have a home on the bottom of the spare tire cover.
  5. ChapmanF
    15,496
    That pushed me to think about it some more, and I finally found a web site with the actual ISO metric thread dimensions and compared them to what I measured, and I'm pretty sure it's M22x2.0 now. So I've gone ahead and ordered a tap and if it works for me, maybe I'll engrave it "PriusChat" and it can circulate to PC gatherings.... :)
    -Chap
  6. Optimus
    Optimus Member
    260
    17
    That must be a fairly expensive tap?
  7. hobbit
    hobbit Senior Member
    4,089
    468
    Bahstahn
    Did you actually get a jack with the car?
    _H*
  8. b2kon
    b2kon New Member
    2001 Prius
    H*...yes, it came with the jack and tire wrench.
    Sorry for the delayed response...I didn't have internet access till now.
    Thanks.
    -Tony
  9. ChapmanF
    15,496
    Well, if valuing the time it took me to find it, yes. :/ None of the hardware stores in town were able to suggest where it could be ordered.
    Anyway, it arrived, M22x2.0 is the correct size, it made short work of the rusty-hole problem, and now there's one conveniently located in west-central Indiana if needed.
    -Chap
