Missing plastic screw?
Discussion in 'Gen 4 Prius Main Forum' started by MrDa7doul, Dec 18, 2021.
  1. MrDa7doul
    MrDa7doul Junior Member
    Jordan
    hello guys, I bought my prius 2017 2 months ago, yesterday while I was filling the washer fluid I noticed missing "plastic screw" between the engine and the air filter (attached).
    I'm wondering if its suppose to be like that?
    thanks in advance.
  2. AzWxGuy
    AzWxGuy Weather Guy
    986
    497
    Tucson, AZ
    2021 Prius
    Not sure what that fitting is as it's way back in there. I probed with a bright light and a small mirror and it looks like some sort of shock absorbing point. There is a rubber bushing in between the top visible piece with a hole in it (drainage?) that is attached to the ICE air filter box and a support structure attached to the intake manifold. No screw noted.
    Elektroingenieur likes this.
  3. Elektroingenieur
    2,515
    3,264
    Three Touring
    I don’t think anything is missing:
    • The Repair Manual (more info) doesn’t show a fastener being removed there. Instead, the two bolts that hold the air cleaner case sub-assembly to its bracket are removed from inside, at the bottom.
    alanclarkeau likes this.
  4. Mendel Leisk
    38,877
  5. MrDa7doul
    Jordan
    Thank you guys for the clarification.
    SM-G965U1 ?
  6. Colorado Boo
    Colorado Boo Active Member
    307
    202
    Monument, Colorado USA
    2021 Prius
    LE AWD-e
    Yep I just got my light out and checked mine...looks the same...that's part of our teeny tiny air filter container. Good eye!!
    Reypac24, MrDa7doul and Mendel Leisk like this.
