Missing Rubber Piece in My Rear Bumper?
Discussion in 'Prius v Main Forum' started by h-dogg, Apr 30, 2019.
  1. h-dogg
    h-dogg Junior Member
    44
    South Bay
    I just got my wife's 2012 Prius v Three back from the body shop after it was rear-ended. Does anybody know if this hole needs a rubber piece next to the battery (passenger rear bumper side)? See the red circle. Sorry about the shakiness on the second pic from the bottom looking up. Battery-View.jpg Bottom-Up.jpg
    Thanks!
  2. Air_Boss
    Air_Boss Senior Member
    3,941
    1,079
    New Yawk
    Battery vent tube?
    Raytheeagle likes this.
  3. Raytheeagle
    Raytheeagle Senior Member
    11,251
    15,481
    Bay Area, California
    2019 Prius Prime
    It ensures the cabin is sealed, but now if there are leaks along the rain gutters along the hatch seal, at least no water will collect;).
    But we haven’t seen similar issues like that of the Gen2 ilk:).
    But I know with @Friendlyx ’s rebuilt Prius, he had issues with moisture so it might be prudent to leave the plug out(y).
  4. h-dogg
    44
    South Bay
    battery vent tube? thanks, i'll look into it. don't want to be driving in the winter with water getting into the battery area.
  5. jzchen
    jzchen Newbie!
    3,298
    1,009
    Arcadia, CA
    Ours has been in a rear end accident as well, so not sure, but there are holes in the vicinity looking from underneath that are not plugged....
  6. h-dogg
    44
    South Bay
    I went back to the body shop and it was plugged. IMG_20190521_180622.jpg Ground view looking up.
    Thanks!
  7. Mendel Leisk
    38,652
    I would check online dealership parts info, there could be a plug for the top side. I think that would be preferable: that area is prone to collect water, and you wouldn't want water getting through that top hole, then being trapped inside.
    Maybe this is the battery vent tube:
    Or maybe just measure the hole diameter, say with drill bits or an inside caliper (if you can get down there), then shop for generic rubber grommets for that hole size. Something like this:
  8. Air_Boss
    3,941
    1,079
    New Yawk
    Yes, that is the battery vent tube...
  9. Mendel Leisk
    38,652
    And this is not the vent tube hole:
  10. h-dogg
    44
    South Bay
    oh good to know..
