missing sd card on prius 2017
Discussion in 'Gen 4 Prius Audio and Electronics' started by h-edris, Apr 27, 2017.
  1. h-edris
    h-edris Junior Member
    Iran
    my prius 2017 had no sd card and it alert me there is no sd map data. how can I make a new sd card for it?
  2. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,592
    near Brisbane, Australia
    I'd talk with your dealer as it should have come with the car if it's needed.
    Ailis O'Riagain likes this.
  3. h-edris
    Iran
    Thanks, but it did not work for me.
  4. Sam Spade
    Sam Spade Senior Member
    2,036
    1,023
    2017 Prius c
    Why ??
    It is possible that there is no map data available for your area........from the supplier of the GPS in that car.
  5. alanclarkeau
    7,045
    7,592
    Sorry, I don't understand - did the dealer say that a SD wasn't available? Or that Map Data wasn't available?
  6. h-edris
    Iran
    car. I checked with Here Co. how prepare the data map, they have some sort of map for my area. I think because the car is imported from the third country maybe the data map was from that country and because of that the dealer said there is no data map on this
  7. h-edris
    Iran
    Yes he said there is no data map. But because without data map a major part of the system does not work, I trying to get a data map which can recognize it.
  8. Elektroingenieur
    2,515
    3,284
    Three Touring
    Duplicating the cards, if it can be done at all, may violate the copyright laws, so I won’t address it further.
    Someone here might be able to tell you a part number for a microSD card that you could buy, however, but we would need to know which navigation system you have. Worldwide, there are over 20 different versions, made by several different Toyota suppliers, and the map cards aren’t necessarily compatible.
    Could you answer these questions, please?
    • In what country was your Prius originally sold as a new car?
    • Which model of Prius do you have? What is its model code? For the cars discussed in this forum, the model code contains “ZVW5” and is stamped or engraved on the same plate as the frame number.
    • Is there an ID number marked on the front of the navigation receiver assembly (the touch-screen unit), in small type near the lower right or lower left corner? Here are a few possible numbers, listed with the corresponding Toyota part numbers, but this is not a complete list:
    ID 100395: FUJITSU TEN, 86140-47260
    ID 100397: FUJITSU TEN, 86140-47340
    ID 100398: FUJITSU TEN, 86140-47290
    ID 100399: FUJITSU TEN, 86804-47370
    ID 100563: FUJITSU TEN, 86140-47370
    ID 510028: PANASONIC, 86140-47270
    ID 510031: PANASONIC, 86140-47360
    ID 510032: PANASONIC, 86140-47310
    ID 510033: PANASONIC, 86140-47350
    ID 510034: PANASONIC, 86140-47300
    ID 510053: PANASONIC, 86804-47330
    ID 510054: PANASONIC, 86804-47340
    ID 510055: PANASONIC, 86804-47360
    ID P10769: PIONEER, 86140-47320
    ID P10771: PIONEER, 86140-47330
    ID P10766: PIONEER, 86140-47380
    ID P10770: PIONEER, 86804-47380
    ID P10974: PIONEER, 86804-47390​
    RCO and alanclarkeau like this.
  9. h-edris
    Iran
    Actually it is a new car but it came to my country from UAE. The model is ZVW5 and the id of navigation is 510055.
  10. alanclarkeau
    7,045
    7,592
    Sorry, I don't understand the logistics of an international purchase, or of your local conditions. Maybe direct contact with TOYOTA would be an option. Hopefully you can sort it out soon.
  11. Elektroingenieur
    2,515
    3,284
    Three Touring
    For a Navigation Receiver Assembly with ID 510055, one compatible microSD card—according to Toyota’s Electronic Parts Catalog—has Toyota part number 86271-60402. The catalog description for this part is “DISC, DISC PLAYER,” but I’m almost certain it is actually a microSD card; the card for my Prius in the U.S. is described the same way.
    This part is unlikely to be available in the U.S. or Japan, but I expect Toyota dealers in the U.A.E. and other GCC countries would have them. There is a seller on eBay offering one for sale, but it’s fairly expensive:
    8627160402 Genuine Toyota DISC DISC PLAYER 86271-60402 | eBay
    I have no information about what countries or regions are covered in the map database on the card; perhaps the seller could tell you if you asked. If you just want a microSD card to stop the error messages, and not to actually use for navigation, you might try to find a compatible card with out-of-date maps. I don’t know if this exists, but if it does, it might be available at a lower price.
    RCO likes this.
  12. randomwalk101
    randomwalk101 DYI'er
    532
    271
    texas
    Find someone with a Prius and borrow their card and copy it onto a blank SD card and use it while waiting for your dealer/Toyota to replace the missing one.
    Diablo6vct likes this.
  13. Prodigyplace
    12,570
    11,782
    Central Virginia
    I doubt they will find one compatible. This is a Prius imported from UAE to Iran.
    RCO likes this.
  14. h-edris
    Iran
    There are several Prius 2017 and other years in my city. There is a Toyota dealer here but it import from UAE. I know
    three person who have the same prius as mine but they also have no SD card.
  15. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    Possibly a State security thing, but I really don't know. (n)
  16. h-edris
    Iran
    Maybe, but I think it is result of Toyota scare of State anger.
    RCO and bisco like this.
  17. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    I wonder if they let a citizen by maps?
  18. tucatz
    tucatz Active Member
    501
    417
    Manzanita, Oregon
    Four Touring
    Can you do this... copy an Sd card, and use it in your Prius?
  19. Elektroingenieur
    2,515
    3,284
    Three Touring
    I haven’t tried, and postings elsewhere suggest that technological protection measures keep at least the obvious methods from working. My Prius came with the latest version of the navigation database (86271-0E184), and I assume if the microSD card were to fail, a dealer would exchange it under warranty, so I haven’t had any reason to take the time (or risk of causing a problem) to investigate further.
    As Toyota notes in their announcement of the 2016 database updates (T-TR-0072-D), the U.S. list price was reduced for 2016. It’s now $169, not $249, and I see Toyota dealers offering the cards online for less. Even so, I expect I’ll wait a few years before buying a new version; I mostly use only the maps, not the points of interest file, and the road network in my area changes slowly.
    I can’t speak for the moderators, of course, but I note that a previous thread on a similar topic was deleted, which suggests to me that PriusChat may not be the best place to discuss techniques, if they exist, for making unauthorized copies of map SD cards, legitimately for backup purposes or otherwise.
    tucatz likes this.
  20. pjm877
    pjm877 Member
    340
    84
    austin, tx
    the SD card has a serial number that can not be changed? That number is keyed to the software on the chip (sd card can not just be copied, and work) . Some here on ebay (usa) are selling the ver that comes with the 2017. I bought one and it is working fine. Good luck on finding a solution.
    map data states it is 05/01/2016.
