  1. best49erfan
    best49erfan Junior Member
    Bushnell FL
    Going home the other day, an animal ran out in front of me and damaged the passenger side of the front bumper. So I went to youtube to see about replacing it and what will be needed. In the video, there looks to be a tank of some sorts and mine is not there. What is this tank for??? I have add a picture for reference.
    49,470
    iirc, it's the resonator part of you engine air intake ductwork
    Skibob, edthefox5 and valde3 like this.
  3. RRxing
    RRxing Senior Member
    2,520
    1,791
    NEPA
    Washer Fluid?
  4. valde3
    valde3 Senior Member
    2,002
    745
    Finland
    Your car will work without one, but it might make a slightly higher engine noise or maybe very slightly worse fuel economy. Also if you're driving in deep water it will suck in water to engine and break the engine easier.
  5. dolj
    dolj Senior Member
    7,651
    3,862
    Wellington, New Zealand
    No. What bisco said. If you don't know the answer, it is better, really, to not to post anything.
  6. VTBIGDOG
    VTBIGDOG Active Member
    211
    146
    That would eliminate half of the posts and make this site totally useful.
  7. RRxing
    2,520
    1,791
    NEPA
    The OP showed a circle around the "Tank" that was missing from a Youtube video, not his/her car. I answered to the best of my ability based on that information. If I can't come up with an educated guess, I don't post. Thank you.
  8. ChapmanF
    15,589
    Possible to mislead readers though. As bisco and dolj have said, it's the resonator.
    Skibob and Mendel Leisk like this.
  9. dolj
    dolj Senior Member
    7,651
    3,862
    Guessing is not helpful. Just don't post. You're welcome.
  10. Tideland Prius
    16,153
    I would’ve guessed washer fluid too. Learned something new. Hostility not needed.
    ice9, Mendel Leisk, bisco and 2 others like this.
  11. dolj
    dolj Senior Member
    7,651
    3,862
    No hostility, just advice on making the board more usable in the long run.
  12. ice9
    ice9 Active Member
    581
    343
    norfolk va
    2018 Prius
    He DID say it with a question mark.
    That is commonly understood as a qualifier - the equivalent of preceding the comment with "I could be mistaken, but..."
  13. ChapmanF
    15,589
    Well, best49erfan DID start a thread with a question - the equivalent of preceding the post with "I've already tried guessing, does somebody either have the answer, or help on where I would find the answer?"
  14. RRxing
    2,520
    1,791
    NEPA
    ...waiting for the OP to post the definitive answer...
  15. Skibob
    Skibob Senior Member
    2,912
    1,496
    Northern California
    I thought it was called the hemholtz resonator?
  16. ChapmanF
    15,589
    Helmholtz, for anybody interested in lookup up the principles involved.
    You can see from the illustration that the intake air doesn't go through it, just over the mouth of it, like playing a bottle.
