Missing undercarriage panel affecting MPGs?
Discussion in 'Gen 3 Prius Fuel Economy' started by Daniel Kutcher, Mar 2, 2022.
  1. Daniel Kutcher
    Daniel Kutcher Junior Member
    30
    Richmond, Virginia
    So yeah, that access panel flap to the oil filter and drain plug is missing. It’s been gone for many years, and I don’t know which technician yoinked it off and didn’t tell me. Anyway, how much is that affecting my MPGs? Would it be worth it to replace that entire body panel ($190)?
    I wonder if there’s a way to fabricate just that section that is missing.
  2. Pdaddy
    Pdaddy Member
    153
    49
    Been discussed before and these break off frequently. Does not effect mileage.
    SM-G960U ?
    Daniel Kutcher likes this.
  3. jerrymildred
    jerrymildred Senior Member
    11,516
    14,120
    Tampa, FL
    Just from that, you might lose about 1/50 of a mpg at interstate speeds. In other words, you won't notice a difference. And no effect at city speeds.
  4. spudnut
    spudnut Active Member
    145
    158
    Idaho Falls/Pocatello, ID
    I still have mine, and it irritated me every time I change the oil, enough so that I built a high enough pair of ramps to allow it to swing fully open. My usual floor jack couldn't get it high enough to get it the heck out of the way.
  5. CR94
    CR94 Senior Member
    2,642
    1,138
    Northwestern S.C.
    I made mine removeable to avoid that problem. The original configuration seems as though they deliberately planned to make DIY oil changes difficult.
  6. Mendel Leisk
    38,753
    The plastic of that panel is too thin/brittle to act as a hinge. More of info in oil change link in my signature.
