Mitsubishi selects Toshiba SCiB battery to power i-MiEV, Minicab MiEV
Discussion in 'Mitsubishi Hybrids and EVs' started by freedom45, Jun 21, 2011.
  1. freedom45
    freedom45 New Member
    24
    Montreal, Quebec, Canada
  2. cashcorn
    cashcorn New Member
    45
    dana point
    Sounds like Tesla Motors, S Model. Competiton is great!!
  3. cyclopathic
    cyclopathic Senior Member
    3,292
    547
    2014 Prius c
  4. freedom45
    24
    I must desagree with you.
    Based on the information published, it seems that SCiB have higher effective capacity versus typical lithium-ion batteries (see below).
    I believe SCiB are really the future of EV. Quick charge, long life and much more...
    Mitsubishi had the largest EV trial here in Quebec/Canada last winter
    (50 EV's). People here were marvelled by the MiEV performance in extreme cold weater.
    Lets hope Mitsubishi Motors can properly execute and provide sufficient EV's to NorthAmercia... This could be a game changer !!! Lets hope..
    Dan
    The SCiB also offers a higher effective capacity than a typical lithium-ion battery, in that more of the stored charge can be used safely before recharging the battery. This, combined with highly efficient regenerative charging during braking or coasting downhill, allows the SCiB to deliver 1.7 times the driving distance per level of charge of a typical lithium-ion battery. This will allow for installation of smaller battery modules in vehicles and contribute to lower EV prices. The SCiB also offers high level performance in a wide range of temperatures, and continues to support rapid charging and excellent power output at temperatures as low as -30ºC.
  5. cyclopathic
    3,292
    547
    2014 Prius c
    what it boils down to is if the capacity is measured by weight or by volume. The NiMH are equal to LiIon by volume, yet ~x4 times inferior by weight.
    either way the achilles of EV is long charge time, so this is a welcome development.
    Sadly you won't be able to charge it in 10min from household outlet.. The biggest draw you typically have allowed is 240V by 30amp (equivalent of A/C circuit), 7.2kW/h. Or about 20-25mi of range per hour.
  6. GSW
    GSW PRIUS POWER
    537
    74
    Jacksonville
    Quote:"The SCiB battery is being manufactured in Toshiba’s Kashiwazaki facilities in Niigata Prefecture on the Japan Sea coast of north east Japan. A new factory dedicated to SCiB production has been built there and started operations in February this year." End Quote
    North east Japan along the coast was were the tsunami hit. I wonder if the new SCiB factory was damaged?
  7. drash
    drash Senior Member
    2,483
    1,256
    Upstate NY
    Yep, agreed. Maybe "real" charging stations can have more V since they are commercial. Then even the 10 minute charge to even 50% could be realized. This would likely kill 2 other technologies, LPG/LP and Fuel Cells, before they get a chance to get traction. Although I knew it wouldn't be long for Fuel Cells to die. And especially if tonyschaefer has anything to say about it.
  8. JamesBurke
    JamesBurke Senior Member
    1,222
    493
    27
    Morgantown, WV
  9. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    2,997
    Fort Lee, NJ
  10. a_gray_prius
    2,927
    782
    IL
    I rode in a development iMIEV. It had a surprising amount of power at the low end - getting to 40mph was effortless for the thing (highest speed limit, it was a residential neighborhood, nearest highway was ~10mi away). Cornered OK, a but more body roll than I'd like.
  11. mrbigh
    3,686
    699
    Long Island, NY
  12. hill
    8,203
    no worries Dan. There IS a sub forum especially set up for mitsubishi - just as there is for ALL of the "other cars". Sub forums is what keeps the Toyota PHEV section from getting too cluttered with "other cars". Anyway, the "other cars" subforum that's especially set up for mitsubishi is called, "other cars".
  13. evnow
    evnow Active Member
    816
    155
    Seattle, WA
    2013 Nissan LEAF
    That is just spin.
    Let us say SCiB is 100w/kg and uses 95% SOC. i.e. 95w/kg.
    LG is 150w/kg and uses 80% SOC i.e. 120w/kg.
    NMC will likely double the density in 3 to 5 years. Where will SCiB then ?
    One thing they didn't talk about in the above linked interview is price. That is where Altairnano suffers.
    I think at this time, SCiB is very good for hybrids, where the above statement might actually be correct. For EVs, SCiB (by their own admission) is not yet ready.
  14. usbseawolf2000
    14,487
    2,997
    Fort Lee, NJ
    Consider the cycle also. SCiB can do 3,000 deep cycles. LG and Nissan battery packs needs to do about 50% SOC windows to get the most cycle and probably would never reach 3,000 cycles. If you use 80% SOC, the pack may last only 1,500 cycles. The cost advantage of LG and Nissan disappears in the long-term.
    The safe SOC window for SCiB also narrows much slower (see the comparison below). Throw in the cold weather performance and you have a very reliable battery that is worth the extra.
