MMO / Marvel Mystery Oil
Discussion in 'Prius c Main Forum' started by Lukey51, Mar 20, 2020.
  1. Lukey51
    Lukey51 Active Member
    204
    108
    TN
    Would running 2 or 3 ounces of MMO in my tank of gas
    1) Do my injectors some good
    2) Be unnecessary
    3) Possibly do some damage
  2. iceman13
    iceman13 Member
    134
    102
    US
    2014 Prius c
    I used it in every fill up for about 10,000mi. Don’t add more than 4oz per tank! I stopped because at the end I believe it was just not going to improve anymore, the injectors were as clean as they can be, maybe. It did improve my MPG slightly over that time. Also now I only use 91 octane fuel or higher because the engine feels smoother between transitions and has more power over very steep hills at high altitude.
    TGrracie, Aaron Vitolins and Lukey51 like this.
  3. audiodave
    audiodave Active Member
    798
    269
    US
    Does 91 improve your milage?
  4. iceman13
    iceman13 Member
    134
    102
    US
    2014 Prius c
    Not really, but I was getting slight pinging with regular gas. It definitely “feels” a lot smother and powerful with 91.
    Lukey51, TGrracie and audiodave like this.
  5. EV Happy
    EV Happy Member
    73
    40
    Sea Foam
    Lukey51 likes this.
  6. Aaron Vitolins
    Aaron Vitolins Senior Member
    1,612
    1,144
    Franklin TN
    I use MMO in 3 of my cars, and my family members cars. I definitely recommend! And can’t go wrong with the price
    Lukey51 and iceman13 like this.
  7. iceman13
    iceman13 Member
    134
    102
    US
    2014 Prius c
    I would like to add that I recommended MMO to my brother because his 1996 Suburban had a slight misfire and it actually helped, it was most likely a dirty injector.
    iPad ?
    Lukey51 and Aaron Vitolins like this.
  8. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,801
    2017 Prius c
    NO. Not unless it is ethanol free.
    The Prius engine has absolutely NO design element that would benefit from higher octane gas.
    Nada. Zilch.
  9. sam spade 2
    7,035
    2,801
    2017 Prius c
    MMO is just light oil. It won't hurt anything.....probably.....but won't help either.
    Extended use might contribute to carbon accumulation.
    Your money would be better spent on a recommended dose of Techron every 5K miles or so.
    And SeaFoam is just snake oil.
    A jack of all trades and master on NONE.
  10. iceman13
    iceman13 Member
    134
    102
    US
    2014 Prius c
    The manual literally says 87 or higher. It all depends on driving conditions, fuel quality, altitude etc.
    audiodave and Lukey51 like this.
  11. sam spade 2
    7,035
    2,801
    2017 Prius c
    Higher than 87 is acceptable.
    If there were some conditions where a higher octane would be desirable, don't you think they would SPECIFY that ??
    Higher altitude requires LESS octane.
    The engine is completely computer controlled do you can't really make it "work harder" by pressing on the accelerator.
    A higher octane rating does not guarantee higher "fuel quality".
    I repeat my statement that using higher octane fuel will NOT accomplish anything useful in these engines.
    The two exceptions are: If the fuel is ethanol free, you should see a slight uptick in mileage.
    If you have REALLY bad carbon deposits or some other engine malfunction that causes a ping or knocking, higher octane fuel might help cover that up.......but won't fix it.
  12. davidc83
    davidc83 Member
    113
    50
    Scottsburg, Indiana
    2015 Prius c
    Correct...Octane does not increase performance...actually it does just the opposite.. octane is a spark inhibitor.. gasoline explodes by 2 main methods: fire-from spark plugs and high compression (reason it is used in sport cars) and our little engines are far from high performance.
    SM-S367VL ?
  13. sam spade 2
    7,035
    2,801
    2017 Prius c
    Gas is not supposed to "explode" inside of an engine.
    It is supposed to burn at a controlled rate and NOT create an explosion.
    That is precisely why a higher octane is needed to prevent an "explosion" in some circumstances.
    dig4dirt likes this.
  14. mikey_t
    mikey_t Active Member
    371
    391
    Los Angeles
    If you want to clean your fuel injectors and fuel line system, I'd recommend BG 44K. I've had good results using it and there isn't anything to worry about.
    #14 mikey_t, Mar 22, 2020
    hotelprisoner and Raytheeagle like this.
  15. dubit
    dubit Senior Member
    850
    538
    23
    Indiana
    2016 Prius c
    If your just looking to clean out your fuel system....
    If you have E15 around your area like we have here. Just run the fuel down to a quarter tank and fill up with E15 gasoline (15% ethanol). Or, fill up your tank, run a couple gallons down and throw in a gallon of E85. (If your curious, I've filled up from a half tank with E85 once - didn't even throw a code) lol
    Your Prius C can run 15% ethanol - even says so on my C's gas cap. But any vehicle manufactured after 2000 can run it.
    Also E15 is cheap - as in very cheap. Right now it's 15 cents cheaper than regular E10. Mileage difference between E15/E10 is about 1.5 - 2.0 mpg. So not enough to be any big deal. I've been running it for - well since I bought the car and I'm getting 50mpg on average.
    Lukey51 likes this.
  16. sam spade 2
    7,035
    2,801
    2017 Prius c
    NOT sound advice.
    Ethanol by itself is not a good fuel system cleaner.
    And there are too many chances for a mistake trying to follow your advice.
    Aaron Vitolins likes this.
  17. dubit
    dubit Senior Member
    850
    538
    23
    Indiana
    2016 Prius c
    E15 is printed on the gas cap that's it's acceptable fuel. As for the E85 at a couple gallons down - only mentioned it because I've done it with waaay more than a few gallons. Genuinely surprised it didn't throw a code.
    But the E15 - been using it for years. In fact, I can't think of a gas station around me that doesn't sell it. Everyone here uses it because it's so much cheaper.
    Rmay635703 likes this.
  18. sam spade 2
    7,035
    2,801
    2017 Prius c
    On YOURS it is. Pretty sure that ALL year models of Prius are NOT like that.
    And the main point is that ethanol in any concentration is not a really good fuel system cleaner......unless maybe the problem really is water.
  19. dubit
    dubit Senior Member
    850
    538
    23
    Indiana
    2016 Prius c
    We're talking about the Prius C here in this thread. Not the regular Prius.
    Lukey51, iceman13 and scona like this.
  20. Lukey51
    204
    108
    TN
    The BP gas I run is supposed to clean the fuel system. I'm not sure if I really need anything more than BP gas.
    I filled it up for $12.01 yesterday and drove 294.4 miles on 6.16 gallons = 47.79 MPGs.
    Gas is down to $1.95 a gallon here.
