Mobil 1 Advanced Fuel Economy 0w-8 - Canada
Discussion in 'Gen 5 Prius Main Forum' started by Probity, Oct 31, 2025.
  1. Probity
    Probity New Member
    Covington LA
    2026 Prius
    A quick question for our northern friends:
    I was in WallyWorld today picking up my 145/90/16 mini-spare (finally arrived, waiting on rim etc from Lewis Toyota), and noticed they had Mobil 1 Advanced Fuel Economy 0w-8 (JASO GLV-1 spec) in stock on their shelves. Was aware of its existence but not that it had made it to Walmart.
    But then when I read the back label saw that it said "Not for Retail Sale in Canada".
    What's up with that?
  2. Hammersmith
    Hammersmith Senior Member
    2,284
    2,288
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    Different government environmental standards. Canada's regulations must be just different enough that it makes financial sense to Mobil to make different blends for the two markets.
    I'm not saying one country's standards are better than the other; just that they're different.
  3. Gokhan
    Gokhan Senior Member
    6,079
    2,409
    Paramount CA
    The only reason is that Canada uses liters vs. quarts in the US. The same oil is sold in both countries otherwise.
    By the way, the four-digit formulation number for all ExxonMobil oil bottles is printed next to the date code on the back label, and you can see exactly which formulation you are getting.
  4. Hammersmith
    2,284
    2,288
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    Well, the specs on the product datasheets between Mobil 1 0W-16 AFE are slightly different between Canada and the US. Viscosities, pour points, flash points are all slightly different. (I didn't compare 0W-8 AFE because it doesn't seem to be available in Canada yet.)
    US Data Sheet:
    Mobil 1™ 0W-16
    Canada Data Sheet:
    Mobil 1™ 0W-16
    It also appears that oil for Canada is made by Imperial Oil, which is a separate company from ExxonMobil, though EM currently owns 69.6% of it.
    #4 Hammersmith, Oct 31, 2025
    Gokhan likes this.
  5. Paul Gregory
    Paul Gregory Senior Member
    2,102
    549
    Alberta
    2024 Prius Prime
    XSE
    It could be something so simple as they didn't wish to pursue certification of the product for the Canadian market.
    Canada has approximately 1/9 the population of the USA.
  6. Paul Gregory
    2,102
    549
    Alberta
    2024 Prius Prime
    XSE
    I worked in the oil & gas industry, and Imperial Oil has been divesting itself of its holdings for many years.
  7. Gokhan
    6,079
    2,409
    Paramount CA
    Those specs are quite different indeed. If @Probity can check the four-digit formulation code for Mobil 1 0W-16 SP in Canada, we can compare it to the US one. If the specs are correct, they are different oils.
  8. Probity
    Probity New Member
    Covington LA
    2026 Prius
    Thanks. Regards possible formulation differences I didn’t take a pic of the Mobil 1 AFE 0w-8 back label on the Walmart shelf so don’t know its formulation code or date code. For grins next time I’m there I’ll do so.
    Note: Gokhan, I saw your posts from ~4-5 yrs ago on BITOG on Toyota Genuine Motor Oil (TGMO), guessing maybe you either are/were in a past life a chemist/tribologist? I learned stuff – never knew within XOM that Mobil 1 and TGMO are separate divisions, TGMO blended by the ExxonMobil Industrial Lubricants division, and Mobil 1 made by the Mobil 1 division, formulations can be quite different. Who knew?
    Regards why USA Mobil 1 AFE 0w-8 isn’t/can’t be retailed in Canada, I was just curious but suspected it ‘might’ be anything from patent blend differences (Imperial-made Mobil 1 vs. US made), or US EPA vs. Canada ECCC and/or US DoT and NHTSA vs. Transport Canada differences.
    Or maybe because the US Mobil 1 AFE 0w-8 is to a JASO standard, whereas both the US and Canada Mobil 1 AFE 0w-16 are to API standards, and something about a JASO spec in Canada causes an issue. IDK, not that important, it is what it is, I was just curious if anyone knew.
    On a side note, interesting XOM stuff on those low viscosity/low volatility synthetic oils blended for the likes of Toyota and others, never would have guessed Noack volatility wt. % that low was possible for the 0w-8 (I'm not allowed to 'link' yet but it's on the Exxonmobil chemical page, products, synthetic base stocks, making engine oils, synthetic base stock innovation page.
    I will continue to find it odd that a ’26 Prius bought in Bellingham WA calls for 0w-8 in the owners manual, and a ’26 Prius bought Vancouver BC calls for 0w-16.
    Gokhan likes this.
  9. msi1259
    msi1259 New Member
    Toronto Ontario Canada
    2026 Prius Plug-in
    My 2026 Prius SE plugin hybrid in Ontario calls for 0W08.
  10. Tideland Prius
    16,537
    Do the Prius and Prius PHEV require different oil weights?
  11. Hammersmith
    2,284
    2,288
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    Looks like Toyota finally switched to 0W-8 for 2026. Both(HEV & PHEV) owner manuals confirm it.
    As for the question, if true, I bet the Vancouver Prius has a lower VIN than the Bellingham one. Changes don't always match up with model years. It's possible the Vancouver car was built just before the switchover and the Bellingham car was built after.
    Or someone made a mistake and the Vancouver car actually does spec 0W-8.
    BTW, all this info is true for both US and Canadian cars(they use the same owners manual).
    #11 Hammersmith, Nov 1, 2025
    Gokhan likes this.
  12. Gokhan
    6,079
    2,409
    Paramount CA
    Same thing happened with Gen 4, switching from 0W-20 to 0W-16 mid-generation. 2020 was the first to switch. I doubt anything changed with the car other than the owner’s manual.
    I would use 0W-8 with Gen 5. If you are heavy-footed, you can benefit from 0W-16 or even 0w-20. I am light-footed to say the least.
  13. Hammersmith
    2,284
    2,288
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    I can't guarantee the parts catalog is completely up to date, but I'm not seeing differences in oil pump or computer part numbers. Only difference I could think of would be the software controlling the variable speed oil pump.
  14. Gokhan
    6,079
    2,409
    Paramount CA
    I doubt that. You could measure the oil pressure in a 2025 and in a 20026 with 0W-8 and compare them. Since the oil pressure is proportional to the HTHS viscosity, you would get 26% less oil pressure with 0W-8 (1.7 cP) vs. 0W-16 (2.3 cP).
  15. Gokhan
    6,079
    2,409
    Paramount CA
    Ha ha ha… My reputation follows me. I don’t post on BITOG anymore. No, I am physicist, but I was an oil enthusiast.
    Mobil 1 is not a company. It is a brand owned by ExxonMobil. ExxonMobil is also the majority owner of Imperial Oil of Canada. ExxonMobil makes all kinds of oils. For example, their HDEO oils are also made by their Industrial Lubricants division as the TGMO is.
    Here is how the date code and revision numbers look like:
    https://bobistheoilguy.com/forums/threads/updated-m1-fs-0w-40-more-pao.347965/page-4#post-5942503
    The first three digits are the blending-plant code, and you can Google it. Chances are that Imperial Oil has a plant in Canada, blending Mobil 1 oils.
    The sale restriction has nothing to do with environmental or oil-spec restrictions. It is a marketing restriction by the companies.
    The Noack-volatility limit for all API and ILSAC oils is 15%. You can read all the specs here:
    Infineum Insight | API engine-oil classifications brochure
    Synthetic oils will have a lower Noack. The Noack will primarily be determined by the base-oil type and viscosity, and for a given base-oil type (GTL, PAO, Group II, etc.), the thinner the base oil, the lower the Noack will be. 0W-8 base oil is typically a lot thinner than the 0W-16 base oil for better fuel economy; so, it will have a lower Noack. The main caveat is not the Noack but that an oil’s wear-protection ability is directly related to its base-oil viscosity, and you will get less and less wear protection when the oil gets thinner and thinner, despite the advanced antiwear/extreme-pressure/friction-modifier additives of today. The rule of thumb is sufficient wear protection, and the OEMs decide how low it is still OK for the oil viscosity.
    I made a base-oil-viscosity calculator and posted it on BITOG. You can find it and plug in the oil specs and get the base-oil viscosity. (Use the standard HTHS values from the Infinemum table if you cannot find the actual values.) Some site administrator thought my calculator was not favoring one of their sponsor engine-oil companies, and that ultimately resulted in me not posting there anymore. He even hid a lot of my original research on base-oil viscosity.
    #15 Gokhan, Nov 1, 2025
    Probity likes this.
  16. Hammersmith
    2,284
    2,288
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    The gen5 Prius and Lexus UX300h both use the same pump(15100-24020) even though the Prius was specced with 0W-16 at the start and the UX300h has been using 0W-8 since the model was introduced last year.
  17. Gokhan
    6,079
    2,409
    Paramount CA
    As long as the oil pressure is above a specified minimum, it is good. That minimum is typically much lower than what you would see even with 0W-8. Oil viscosity and therefore the oil pressure changes greatly with temperature anyway.
    The main concern is the base-oil viscosity, which determines the wear protection of the valvetrain and piston rings, as it determines the oil-film thickness in the boundary-lubrication and mixed-lubrication regimes, but Toyota thinks that 0W-8 provides adequate wear protection.
  18. KMO
    KMO Senior Member
    1,935
    667
    Finland
    2023 Prius Prime
    I don't see any changes for the pump in the parts catalogue either, but there are new pages for 202507 onwards in New Car Features for the oil pump and filter.
    There's no obvious difference between the old and new pages - only thing is that the pump in the illustration may be slightly different looking.
    Also the NCF seems to be saying that the oil level sensor has been removed after 202507. (I didn't know it actually had one...), and the parts catalogue confirms. That's only connected to the combination meter, and the combination meter has new part numbers from 202507, presumably to stop monitoring that sensor.
    So there are some oil-related changes, coinciding with and likely connected to the change to 0W8 specification.
    The new European manuals specifying 0W8 are dated 2025-07 too, and the service data sheet has a new section for 202507 onwards listing 0W8. There's no retrospective 0W8 listing for older cars.
    #18 KMO, Nov 2, 2025
  19. Probity
    Probity New Member
    Covington LA
    2026 Prius
    Thanks for the clarification. Obviously operator error my first look at Toyota Canada OM (probably opened 2025 OM instead of 2026), opened the 2026 OM and yes same 0w-8 as in 2026 Toyota US OM. Another reminder to measure twice/cut once.
  20. VelvetFoot
    VelvetFoot Member
    441
    128
    New York State
    2026 Prius
    Interesting.
