Mobil 1 Toyota 0W-20 oil analysis in Insight hybrid
Discussion in 'Gen 2 Prius Technical Discussion' started by Troy Heagy, Oct 30, 2013.
  1. Troy Heagy
    Troy Heagy Member
    1,218
    If I recall correctly, the G3 was the first Prius to switch from xW-30 to xW-20 oil. Here is an oil analysis I did comparing Mobil 1 versus Toyota's own oil (in a Honda engine). The Toyota oil performed just as well as the Mobil synthetic (except the T oil had high acid content):
    Mobil 1 0w-20 on the left
    Toyota 0W-20 on the right
    1.0 liter 3-cylinder, 2006 Insight hybrid
    4000 mile intervals, 134k on engine
    BLACKSTONE: We like steady wear trends, and they don't get much steadier than this! We always say that it takes three samples to build a solid trend line, but the first two reports show nearly identical levels of wear after similar oil runs, so you're off to a really good start for this Insight. No moisture, dirt, or fuel was detected, so the oil was once again free of harmful contaminants, and there were no signs of air or oil filtration problems (low silicon and insolubles)
    M1 ------- TOY
    2 ALUMINUM 3
    0 CHROMIUM 0
    4 IRON 4
    2 COPPER 2
    0 LEAD 0
    0 TIN 0
    77 MOLYBDENUM 109
    0 NICKEL 1
    1 MANGANESE 1
    0 SILVER 0
    0 TITANIUM 0
    0 POTASSIUM 1
    94 BORON 18
    12 SILICON 5
    4 SODIUM 5
    1414 CALCIUM 2305
    747 MAGNESIUM 125
    693 PHOSPHORUS 790
    788 ZINC 906
    0 BARIUM 0
    50.5 SUSvisc210F 50.4
    7.43 CSTvisc100C 7.40
    415 Flashpoint 425
    4.5 TBN 4.1
    0.8 TAN 2.9
    uart likes this.
  2. fotomoto
    fotomoto Senior Member
    5,602
    3,778
    So. Texas
    Troy,
    I'm not sure what you did. Did you run M1 in the Honda and then drain/fill with Toyota? Or do you have also own a Prius and are comparing two cars/engines?
  3. Troy Heagy
    Troy Heagy Member
    1,218
  4. Britprius
    Britprius Senior Member
    5,194
    1,914
    Herefordshire England
    Troy, the 2008 gen2 also uses 0w20 oil in the UK, but possibly different in the US or other countries. The only clue to your possible location is that you use Blackstones for your oil analysis.
    John (Britprius)
  5. uart
    uart Senior Member
    4,215
    1,200
    Australia
    Nice results Troy. Those wear metals are about as low as you could possibly get. Looking at some of those numbers you could almost think you were looking at a virgin oil sample. :)
