MOBIL 1 what type? '08 105k
Discussion in 'Gen 2 Prius Main Forum' started by Baldbubba, Sep 12, 2014.
  1. Baldbubba
    Baldbubba Member
    142
    27
    in PRIUS down by the river
    I have a 2008 gen2 with 105 k which type mobil 1 oil should I use?
    Mobil 1 Advanced Fuel Economy?? or
    Mobil 1 High Mileage ??
    what weight? should i purchase?
  2. wjtracy
    wjtracy Senior Member
    11,374
    3,609
    Northern VA (NoVA)
    Assuming that river you live by is in the US, Gen2 takes either 5w-30 or 0w-30.
    This time of year I normally go to 0w-30 Mobil-1 Advanced Fuel Economy on the hopes the oils flows better at low winter temps. The High Mileage Mobil-1 does not claim to be as good as other Mobil-1 for MPG, and is intended if you are having leaks or other oil loss issues. In the summer I tend to use the 5W-30 Extended Drain in case I feel like procrastinating past 7000 miles on the next oil change.
    PriusGuy32 likes this.
  3. Easy Rider 2
    Easy Rider 2 Senior Member
    1,584
    258
    Ocala, FL
    And I would only add:
    I would personally advise you to stick with whatever has been used in the past, if you know.
    After 100K miles, there really is no good reason to switch to synthetic; your money would probably be better spent with slightly more frequent changes.
    That is assuming that you don't have issues with excess oil consumption (or loss).
  4. Baldbubba
    Baldbubba Member
    142
    27
    it has mobil 1 in it now,,,, just making sure i am putting i really should in it..... i change every 10k since i have owned it which is 18 months... it uses less than half a quart in that 10 k,, i usually purchase 4 qt to change it ,, and i try to check it every other time i get gas,, and it will use what is left of the that 4th quart that i dont put in when it is changed....
  5. Easy Rider 2
    1,584
    258
    Ocala, FL
    OK then see tracy's post above. (y)
  6. wjtracy
    11,374
    3,609
    Northern VA (NoVA)
    I guess the only thing left to say is:
    I too miss SNL's Chris Farley and his "van down by the river sketch"
    Fifine likes this.
  7. skruse
    skruse Senior Member
    1,454
    97
    Coloma CA - Sierra Nevada
    I have used Mobil 1 synthetic oil and Mobil oil filters from day one (160,000 mi). I usually purchase Mobil 1 oil by the case at Costco and keep it on hand. On those times when I have had a commercial oil changer do the oil change I bring my own Mobil 1 synthetic oil and oil filter. I purchase Mobil 1 filters in lots of 10 through Amazon. It just turns out our Toyota Echo and Prius use the same filter.
  8. Big bad john
    Big bad john Junior Member
    Victorville, CA
    That's what I use too. Mobile 1 5W30 from Costco when it is on sale. I use either Toyota filters when the local dealer sends coupons, or Bosch filters from Autozone. We have 173,000 miles on our 2005 and it doesn't use any oil. I do change it every 5000 miles when the light comes on.
  9. Mendel Leisk
    42,195
    An alternative: you can get Toyota's 0W20, if you're at the part counter getting the filter and washer anyways. At our nearby dealership it's $5.65 per liter.
  10. wjtracy
    11,374
    3,609
    Northern VA (NoVA)
    ...same here except Walmart stopped carrying the filters in my store (last time I looked you culd still get online at Walmart) so I started getting other filters
  11. Big bad john
    Victorville, CA
    my manual specifies 5W30 for my 2005 Prius.
  12. Mendel Leisk
    42,195
