Mobil1 0W20 Oil analysis reports
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by TheForce, Jul 27, 2007.
  1. TheForce
    3,461
    537
    Wheelersburg, Ohio
    I will be using Blackstone Labs.
    Date 07/07/09
    Miles on oil: 5322
    Miles on engine: 15007
    Its still a new engine so the silicon content is OK. They said I could try for 6k miles next. I don't think I will though.
    TBN: 2.7
    Universal Averages are in [ ]
    Aluminum: 3 [3]
    Chromium: 0 [1]
    Iron: 11 [10]
    Copper: 3 [6]
    Lead: 1 [5]
    Tin: 0 [1]
    Molybdenum:79 [20]
    Nickel: 0 [0]
    Manganese: 0 [0]
    Silver: 0 [0]
    Titanium: 0 [0]
    Potassium: 2 [1]
    Boron: 41 [21]
    Silicon: 28 [15]
    Sodium: 4 [5]
    Calcium: 1942 [1696]
    Magnesium: 12 [157]
    Phosphorus: 650 [741]
    Zinc: 742 [859]
    Barium: 1 [1]
    Sub Visc @210F: 52.5 [51-59]
    Flashpoint in F: 355 [>355]
    Fuel%: TR [<2.0]
    Antifreeze%: 0.0 [0.0]
    Water%: 0.0 [<0.1]
    Insolubles%: 0.3 [<0.6]
  2. Doc Willie
    1,717
    142
    Out there, somewhere
    OOOOooo. Nice numbers.
    Uhhh. What do they mean? Medical lab reports come with the "normal" values in parenthesis after each reported value.
  3. TheForce
    3,461
    537
    Wheelersburg, Ohio
    Updated with universal averages. Maybe this will help?
  4. Priusaurus110
    Priusaurus110 Junior Member
    31
    Monument, CO
    TheForce: thanks for the oil analysis tracking...I also use Mobil1 in my 2005 Prius and have been curious about how long I can go between oil changes.
    I do have some more interpretation questions for you, however:
    1. what is significance of very high moly level (more than 3 times avg)?
    2. Same question with the boron level (twice the universal avg).
    thanks
  5. MickeyA
    MickeyA New Member
    81
    Only surprise is the TBN is "down" to 2.7 @ ~5300 miles.
    I would have expected it to have more life than that in the vaunted M1.
  6. ScottY
    ScottY New Member
    1,250
    Long Island, NY
    <div class='quotetop'>QUOTE(Priusaurus110 @ Jul 28 2007, 12:48 AM) [snapback]486547[/snapback]</div>
    http://www.blackstone-labs.com/gasoline_di...eport_expl.html
  7. TheForce
    3,461
    537
    Wheelersburg, Ohio
    They did not comment on those two items but said that they normally expect wear-in to be past by about 10k miles. Since I have been changing my oil every 5k the wear-in may take longer versus the normal 3k.
    My guess is that those higher numbers is normal for new engines and each oil change should flush out that crap. Only my next oil report will tell if thats true.
  8. tochatihu
    tochatihu Senior Member
    9,059
    3,529
    Kunming Yunnan China
    2001 Prius
    It would be good to combine your UOA with maineprius947's thread on this topic in care maint and TS:
    http://priuschat.com/Used-Oil-Analysis-UOA...val-t27461.html
    Concerning the rapid early decay of TBN, neptune spacebears found something like exponential decay testing Mobil 1 and AMSoil in a different car. Jay Groh's results are consistent with that pattern.
  9. jayman
    jayman Senior Member
    13,439
    640
    Winnipeg Manitoba
  10. PA Prius
    PA Prius Active Member
    754
    241
    SE Pennsylvania
    What is TBN?
    I use Amsoil 0W30 and change every 10,000 miles (6 months). I have not had a UOA done.
    PA P
  11. IsrAmeriPrius
    IsrAmeriPrius Progressive Member
    4,333
    Southern California
    <div class='quotetop'>QUOTE(PA Prius @ Jul 29 2007, 11:32 AM) [snapback]487136[/snapback]</div>
    Total Base Number
  12. tochatihu
    9,059
    3,529
    2001 Prius
    TBN measures the oil's remaining capacity to neutralize acids produced in fuel combustion, and slipping past the piston rings (or other access pathways to the oil). A new oil starts with TBN from about 8 to 11, depending on its additives.
    According to the TBN technique Blackstone uses, a value of 2 means 'almost gone' and 1 means 'let's change oil now". But I don't know why its decay appears non-linear through time.
    With synthetic oils in Prius (based on data so far) TBN is the first thing to go. Viscosity seems stable, and the engine is not usually releasing enough crud to degrade the oil's lubrication.
  13. richard schumacher
    7,663
    1,038
    United States
    Why do you use the wrong weight oil?
  14. jayman
    13,439
    640
    Winnipeg Manitoba
    <div class='quotetop'>QUOTE(richard schumacher @ Jul 29 2007, 11:47 PM) [snapback]487307[/snapback]</div>
    5W-30 is a sort of "universal" viscosity in North America. It's part of the API/Big Oil culture to promote frequent oil changes. By having "universal" viscosity, all those qwickee loob places only have to stock one giant tank of crap oil.
    Consider that a similar motor, in a Honda, requires a 5W-20. The tolerances are almost identical. At normal operating temperatures, a 0W-20 and a 5W-20 will test out almost identical. Indeed, a *stable* synthetic 0W-20 will hold up better than a conventional 5W-30 that falls apart under stress.
    In the rest of the world, people usually chose a viscosity based on ambient conditions. For the same exact motor, that could mean a 15W-40.
    If used oil analysis supports it, a lower viscosity usually results in LESS motor wear. There is much less "pumping" loss from using a lighter oil, the start up lubrication is much more reliable, and as a result there is a minor improvement in fuel economy. For most of the motors out there, no matter what make, a 0W-20 will provide good used oil analysis numbers
    IMHO if you regularly operate in winter temps down to -40, like I do, then a synthetic 0W-30 or 0W-20 is a must.
    Ironically the first place I saw a synthetic 0W-30 was at a Pep Boys in Utah. Nobody in Canada carried it, with the exception of Esso and their heavy duty version, XD-3 0W-30.
  15. TheForce
    3,461
    537
    Wheelersburg, Ohio
    [edit] corrected values for universal averages.
    New results are in.
    Date 07/11/14
    Miles on oil: 5054
    Miles on engine: 20061
    No problems were found in the latest sample from your Prius. Wear generally improved with the shorter oil run, not that the last oil was run too long. The low wear trends that your engine is beginning to produce are some of the best indicators that we know of that an engine is operated and maintained well. The oil was in good shape physically, containing no moisture, fuel, or coolant. The air and oil filters are working well too. The TBN read 3.0 so you had some active additive remaining
    TBN: 3.0
    Aluminum: 3 [3]
    Chromium: 0 [0]
    Iron: 8 [10]
    Copper: 2 [4]
    Lead: 0 [3]
    Tin: 0 [1]
    Molybdenum: 89 [47]
    Nickel: 1 [0]
    Manganese: 0 [0]
    Silver: 0 [0]
    Titanium: 0 [0]
    Potassium: 2 [1]
    Boron: 54 [35]
    Silicon: 20 [19]
    Sodium: 5 [6]
    Calcium: 2122 [1880]
    Magnesium: 10 [94]
    Phosphorus: 652 [690]
    Zinc: 791 [813]
    Barium: 0 [0]
    Values should be at certin value in [ ]
    Sub Visc @210F: 53.2 [51-59]
    cSt Viscosity @ 100°C: 8.24 7.6-10.2
    Flashpoint in F: 380 [>355]
    Fuel%: <0.5 [<2.0]
    Water%: 0.0 [<0.1]
  16. bwilson4web
    15,518
    <div class='quotetop'>QUOTE(TheForce @ Nov 21 2007, 04:09 PM) [snapback]542616[/snapback]</div>
    What are "Universal Averages []"?
    Do you have a reference or virgin oil sample?
    I loaded your numbers into a spreadsheet and noticed the following were up: Calcium, Zinc, Phosphorus, Molybdenum and Boron. These are typically found in oil additives and this suggests the second oil might have come from a different batch. Could it have been the 'extended' use version?
    Your Silicon, Magnesium and Iron rates were lower, a very good thing. The rest of the elements were so low that we can't really draw any conclusions.
    It looks like your first oil change was actually a flush. The second change shows lower rates of wear material, you've made it cleaner, and higher rates of additives, suggesting possibly a change in formulation by the vendor or a better grade, perhaps the extended use oil.
  17. TheForce
    3,461
    537
    Wheelersburg, Ohio
    From blackstone labs website its says the universal averages are the avarages from this type of engine.
    I just looked over my post and my oil report and I need to changed the averages.
    The oil is the same Mobil1 0w20 that I got from autobarn.com from my last oil change. Only difference is that on this change I used a Mobil1 filter. I used a toyota oil filter on the previous oil change.
    Blackstone labs said that the first one was a little high but since it was a new engine it was expected.
  18. bwilson4web
    15,518
    <div class='quotetop'>QUOTE(TheForce @ Nov 21 2007, 09:10 PM) [snapback]542758[/snapback]</div>
    Don't do it for me. I am always more interested in comparing oil to a "reference sample." This gives us the additives so we can tell how they changed over time.
    My references state that additive loads change by batch and this would make sense. I find it hard to believe the filter caused the additives to go up. I agree with Blackstone that the first change was a flush.
    I'm attaching the Excel spreadsheet I used to look at your results. Let me suggest you download it and use it in the future to track your progress.
    GOOD LUCK!
  19. TheForce
    3,461
    537
    Wheelersburg, Ohio
    Well I still have another sample container so I may send it off with some new oil to see what the results are. Just dont know if I want to spend the money to do that yet.
    Bob you are the graph king! If I ever get my PC to capture data from my Can-View I would like you to analize my data since my xcel graphing knowledge is slacking plus I dont use xcel I use OpenOffice. Its about the same as xcel but I still dont know how to use it very well to make graphs. Thats if you dont mind doing that for me. :D
  20. bwilson4web
    15,518
    <div class='quotetop'>QUOTE(TheForce @ Nov 21 2007, 09:43 PM) [snapback]542768[/snapback]</div>
    I take it you were able to see the graph?
    It has been a while since I used OpenOffice but I think it can handle the graphs too. The trick is using a log scale on the Y axis. This let's you see the change in the very high additives as well as the much lower, orders of magnitude lower, wear material.
    GOOD LUCK!
