Mode $06 report generated by Torque for Android
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by patcoghm, Apr 3, 2019.
Tags:
  1. patcoghm
    patcoghm Junior Member
    57
    2006 Prius 168,002 miles. After replacing the VVT valve, the code P0011 disappeared and no codes since. It also solved power at high speed on freeway when climbing mountains. After the VVT valve was replaced the codes disappeared. Also replaced the battery in an attemp to solve battery tempatures, and that has been fixed after Toyota found they forgot Air Dames when they replaced the battery. That was my only problems.
    I just ran a test that showed the below information.
    The question is do I have a problem with the 3 Failures in the test report, and what do they mean..............
    MID:$03 TID:$01
    Rich to Lean sensor threshold voltage(constant) - O2 Bank 1 Sensor 3
    Max: 1,395 Min: 16,193
    Test result value: 16,710
    FAIL
    MID:$41 TID:$0c
    Misfire counts for last/current driving cycles(calculated) - O2 Heater Monitor Bank 1 - Sensor 1
    Max: 65 Min: 769
    Test result value: 65
    FAIL
    MID:$46 TID:$3f
    - O2 Heater Monitor Bank 2 - Sensor 2
    Max: 48,671 Min: 16,640
    Test result value: 1,395
    FAIL
    Here is the full report..................
    Vehicle VIN: Not present
    Vehicle Manufacturer: Unknown
    Vehicle Calibration ID: 34709000
    A A
    A AF?AqA ¾¨
    Test report:
    MID:$01 TID:$8e
    - O2 Bank 1 Sensor 1
    Max: 7.99527 Min: 0
    Test result value: 1.80286
    PASS
    MID:$01 TID:$91
    Max: 3.58984mA Min: 1.40625mA
    Test result value: 2.26953mA
    PASS
    MID:$02 TID:$07
    Minimum sensor Voltage for test cycle(calculated) - O2 Bank 1 Sensor 2
    Max: 0.233V Min: 0V
    Test result value: 0.095V
    PASS
    MID:$02 TID:$08
    Maximum sensor Voltage for test cycle(calculated) - O2 Bank 1 Sensor 2
    Max: 65.535V Min: 0.605V
    Test result value: 0.8V
    PASS
    MID:$02 TID:$8f
    Max: 1.19895 Min: 0
    Test result value: 0.11193
    PASS
    MID:$03 TID:$01
    FAIL
    MID:$21 TID:$a9
    - Catalyst Monitor Bank 1
    Max: 9.99393 Min: 0.1098
    Test result value: 0.12383
    PASS
    MID:$3d TID:$c8
    - EVAP Monitor (0.020")
    Max: -0.294kPa Min: -32.768kPa
    Test result value: -1.563kPa
    PASS
    MID:$3d TID:$c9
    Max: 32.767kPa Min: 0kPa
    Test result value: 0.198kPa
    PASS
    MID:$3d TID:$ca
    Test result value: 1.65kPa
    PASS
    MID:$3d TID:$cb
    Test result value: 0.99kPa
    PASS
    MID:$3d TID:$cd
    PASS
    MID:$3d TID:$ce
    Test result value: 1.628kPa
    PASS
    MID:$3d TID:$cf
    Test result value: 0.968kPa
    PASS
    MID:$3d TID:$d0
    Test result value: 2.838kPa
    PASS
    MID:$3d TID:$d1
    PASS
    MID:$3d TID:$d4
    PASS
    MID:$3d TID:$d5
    PASS
    MID:$3d TID:$d6
    Max: 327.66998 Min: -4.3
    Test result value: 0.97
    PASS
    MID:$41 TID:$0c
    Max: 65 Min: 769
    FAIL
    MID:$46 TID:$3f
    FAIL
    MID:$a1 TID:$0b
    EWMA Misfire counts (average) for last 10 drive cycles - Misfire Monitor General Data
    Max: 65,535Count Min: 0Count
    Test result value: 0Count
    PASS
    MID:$a1 TID:$0c
    Misfire counts for last/current driving cycles(calculated) - Misfire Monitor General Data
    PASS
    MID:$a2 TID:$0b
    EWMA Misfire counts (average) for last 10 drive cycles - Misfire Cylinder 1 Data
    PASS
    MID:$a2 TID:$0c
    Misfire counts for last/current driving cycles(calculated) - Misfire Cylinder 1 Data
    PASS
    MID:$a3 TID:$0b
    EWMA Misfire counts (average) for last 10 drive cycles - Misfire Cylinder 2 Data
    PASS
    MID:$a3 TID:$0c
    Misfire counts for last/current driving cycles(calculated) - Misfire Cylinder 2 Data
    PASS
    MID:$a4 TID:$0b
    EWMA Misfire counts (average) for last 10 drive cycles - Misfire Cylinder 3 Data
    PASS
    MID:$a4 TID:$0c
    Misfire counts for last/current driving cycles(calculated) - Misfire Cylinder 3 Data
    PASS
    MID:$a5 TID:$0b
    EWMA Misfire counts (average) for last 10 drive cycles - Misfire Cylinder 4 Data
    PASS
    MID:$a5 TID:$0c
    Misfire counts for last/current driving cycles(calculated) - Misfire Cylinder 4 Data
    PASS
    End of report.
  2. dolj
    dolj Senior Member
    8,563
    4,350
    Wellington, New Zealand
    You need to buy the Torque Pro app (~$6), load the Prius specific PIDs and then run the test again.
    SFO likes this.
  3. patcoghm
    57
    Thanks. Did the Pro version and it passed without problems. This app is full of good things. It shows the HVB each cell and all the tempature sensors. This summer when its warm I will give that a good test when its pushing 100 outside.
