Model III interior measurements question
Discussion in 'Gen 3 Prius Technical Discussion' started by PRI6080, May 29, 2019.
  1. PRI6080
    PRI6080 Junior Member
    22
    Hi Guys,
    My question is this: I'm looking at purchasing an awning that comes in a box that measures 102"(about 8.4ft)in length and about 6" in width and height. Do you think that with the front passenger seat folded down, as well as the rear, that this box would fit in a diagonal orientation on the inside of the Prius?
    49,371
    best bet might be to leave the back seat up and slide it up against the windshield, or into the passenger footwell.
    PRI6080 and Mendel Leisk like this.
  3. jerrymildred
    jerrymildred Senior Member
    11,508
    14,109
    Tampa, FL
    Eight feet is an easy fit with front and back seat down. At 8'-4", you might need to put the front end on the dash on a pillow. Not sure the hatch would close if you left the seats up and put it on them.
    PRI6080 likes this.
  4. Mendel Leisk
    38,644
    If it absolutely won't fit, let it hang out a bit, push a carabiner into the hatch threshold latch, push a piece of pipe foam insulation onto the lip of the hatch, loop a rope through the hatch tang and the carabiner, and synch the hatch tightly down against your package. If it sticks out significantly put a red flag on the back.
    You will likely have to contend with a constant warning beep. Also, it'd be good to drive with windows down, though I doubt there'd be CO issues, but who knows.
    #4 Mendel Leisk, May 29, 2019
    jerrymildred and PRI6080 like this.
  5. PRI6080
    22
    I would fold the rear seats down and put one end at the far corner of the trunk.
  6. jerrymildred
    11,508
    14,109
    Tampa, FL
    I'm almost positive you'll be fine, but probably need the front seat down, too. And @Mendel Leisk has a great back-up idea in case something goes awry.
  7. CR94
    CR94 Senior Member
    2,642
    1,137
    Northwestern S.C.
    I recently carried a 7'4" tall grandfather clock, by pushing the right front seat all the way forward and all the way back, approximately level with the folded-down rear seat. There appeared to be around one foot clearance between the dash and the top of the clock.
    Removing the seat would allow long straight cargo to extend farther forward.
    That bugger was heavy, too!
    PRI6080 and jerrymildred like this.
  8. PRI6080
    22
    FYI : The awning I picked up fit inside the Prius with room to spare. Pretty amazing.
    jerrymildred and bisco like this.
  9. bisco
    49,371
  10. jerrymildred
    11,508
    14,109
    Tampa, FL
    Cool! I was pretty sure it would, but it's always easier to say, "Aw, it'll fit! No problem." when it's me and my car than someone else's car. ;)
  11. Grit
    Grit Senior Member
    6,139
    4,053
    Wilkes Land
    Phhotos?
