Modifications Req. to use Gen 2 modules in Gen 1 Battery
Discussion in 'Generation 1 Prius Discussion' started by carl511111, Nov 10, 2015.
  1. carl511111
    carl511111 Junior Member
    Bradenton, FL
    2016 Prius c
    So, I'm rebuilding my Gen 1 Prius' HV battery with Gen 2 modules and I see that the Gen 2 modules are ever so slightly wider than the Gen 1's. All the holes in the bottom of the case obviously will not line up, Bus bars will not slide on the terminals properly and temp. sensors will not clip in. I searched dozens of prior posts/threads to try to get the answer myself, but have not found where this has been previously addressed(though I'm sure it has). I know many people have successfully rebuilt Gen 1 batteries with Gen 2 modules SO, what modifications are required and how are they done? Thank you, in advance, for all members weighing in with advice!!
  2. greasemonkey007
    greasemonkey007 Active Member
    287
    106
    South Central Arkansas
    I'm pretty sure that your problem is that you're not squeezing the modules together to get the screw holes lined up. If you simply stack them in there you won't get the screw holes to line up, at least not for long.
    The gen 2 mods only have a screw hole on one end, so you'll only use 1/2 the screws. And they will line up, though they have to be "persuaded", especially the farther you go. I use a bar clamp, a couple of small blocks of wood, and a rubber mallet. The bus bars will definitely work as well. As for the temp sensor, I use a small zip tie to hold them in place. I think 2 bar clamps would work a little better than 1, but I just make do. Use the wood to spread the force of the clamp (as minimal as possible) over the module and pull it in to line up the holes.
  3. Larry Reilly1948Fatcorn
    Waterloo, Iowa
    Do you need to replace other things besides the battery cells when going from Gen 1 to Gen 2 cells? I suppose the Gen 2 battery tray cannot fit in a Gen 1 vehicle? I thought I might just buy a whole Gen 2 battery pack if I can fit it in the Gen 1 vehicle.
  4. ammdb
    ammdb Active Member
    281
    113
    Indianapolis
    Gen 2 battery packs are not compatible with the Gen 1 Prius. They have 10 fewer modules and run at a lower voltage than Gen 1.
    Bruce Berquist likes this.
  5. Bruce Berquist
    Bruce Berquist Junior Member
    95
    26
    South Tamworth, NH
    2003 Prius
    I
    You can replace the cells with gen2 cells, as has lredy been shared, but the gen2 battery assembly will not be compatible with the gen1 hybrid system. At least a couple of the ECUs will be thrown off by the lack of voltage and the missing number of sensors that normally come with the gen1 battery assembly.
  6. Martin1973
    Martin1973 New Member
    Bourne Lincolnshire uk
    2002 Prius
    ----UK----
    I am currently running a general with mixture of general and general batteries. Working just fine and has been for ages.
    The g2 are slightly wider so I made the mounting holes wider, the temp sensors clip in ok.
    As do the breather tubes.
    No ecu issues
