Modifying the OEM turn flasher to one-touch line change (3 blinks) and LED lamps
Discussion in 'Gen 3 Prius Audio and Electronics' started by Dejan, May 13, 2020.
  1. Dejan
    Dejan Junior Member
    Belgrade, Serbia
    During the corona isolation I killed time by "upgrading" the 81980-50030 flasher with 555 timers (one per side), so now, when I lightly press the turn signal lever, the flasher flashes 3 times. It turns out that it’s one time-consuming job with an eyesight and patience test because I made a “sculpture” of components inside the existing relay box. Also, I modified the relay so it doesn’t check the presence of the light bulbs so I can replace them with LED ones without added resistors. Here are some pictures and the final schematic – I changed it according to the available components in my handy “scrapyard”.
    Maybe someone will find this useful.
  2. StarCaller
    StarCaller Senior Member
    1,277
    729
    Cedar Crest, NM, USA
    rather get one of those, easier:
    TapTurn - home
    neway, not too bad of a job what you did !
    Kajus likes this.
  3. NewHybridOwner
    NewHybridOwner Active Member
    607
    283
    W. Michigan
    SWMBO wouldn't have to keep reminding me to cancel the flashers after merging into the freeway.
  4. abubin
    abubin Member
    193
    92
    Malaysia
    Wow..that is the pro level DIY of doing something with complicated process.
    I replaced the flasher relay and it's adjustable so I can control the flashing speed.
    AzusaPrius likes this.
  5. Dejan
    Dejan Junior Member
    Belgrade, Serbia
    I’m aware of that turn flasher from AliExpress. I even purchased one but the seller “mistakenly” sent me the original one and that’s the one I modified. Are the comments correct when claiming that that model has a 1sec delay before it starts flashing?
    Corona gave me the time to modify my car even more, so now it has automatic lights using a already existing sensor, foot lights (also using an oem signal), video-in from an android phone hidden in the glove box.
    This car is really asking to be modified.
    2012 Prius v wagon 3 likes this.
  6. edthefox5
    edthefox5 Senior Member
    10,096
    4,833
    Clearwater, Florida
    After getting whacked hard twice in the rear on my G2 I added a motorcycle blinker kit to the center brake light. Very very noticeable. Have it set to 4 blinks every time the brake pedal is pushed.
    Haven't been hit since that was 8 years ago. All my cars have it.
  7. Leadfoot J. McCoalroller
    8,093
    7,577
    Pennsylvania
    2018 Prius c
    I'm looking for one that only blinks every 2-3 minutes or so. Meaning it flashes the first time you hit the brakes, then switches to simple pass-thru for the next few minutes. I want to be seen, but I don't need it to be a constant visual nuisance either.
    Johnny Cakes likes this.
  8. edthefox5
    10,096
    4,833
    Clearwater, Florida
    Sorry not sure what you mean.....
  9. Leadfoot J. McCoalroller
    8,093
    7,577
    Pennsylvania
    2018 Prius c
    I don't want it to flash every single time I hit the brakes, because that would be annoying to somebody behind me for a long time i.e. dense traffic.
    I want it to do the blinky thing when I hit the brakes. And then NOT blink if I use the brakes again within the next 2 minutes of that moment.
    Once I make it 2 minutes without brakes, the blink will arm itself again. Rinse, repeat. I've now found a few that can do it, just trying to decide whose is best.
  10. LukUsc
    LukUsc Member
    69
    26
    Poland
    In my opinion, the best option would be when it started flashing only when we pressed the brake hard and it shone normally when we braked gently. Just like it is in OEM cars. Flashing every time can really piss someone off :)
  11. ASRDogman
    ASRDogman Senior Member
    7,606
    3,915
    In most states you are not suppose to have flashing brake lights, or other lights.
    Unless you have an emergency vehicle or maintenance vehicle.
    And usually if someone is pumping there brake lights it means someone seriously is happening in
    front of them and they are trying to warn those behind them.
  12. RRxing
    RRxing Senior Member
    2,546
    1,822
    NEPA
    This is the default operation in the USA. I used Carista to change it from three to five flashes.
  13. Leadfoot J. McCoalroller
    8,093
    7,577
    Pennsylvania
    2018 Prius c
    Legal compliance is retained by never extinguishing the brake lamp in question. The apparent blink is achieved by cycling between full and partial brightness. The better flasher modules accommodate this function.
    @LukUsc Some also incorporate their own G-meters; you can have the flash function only when a certain threshold deceleration occurs.
  14. Dael
    Dael Member
    137
    32
    Ohio
    2020 Prius Prime
    dealer couldn't find Three-five blinker setting in 2020 obd Sept. 2019 delivery
  15. edthefox5
    10,096
    4,833
    Clearwater, Florida
    I have a motorcycle blinker in all my cars set to blink just the center brake light. It’s set to blink 5 times
    My g2 was hit multiple times in the back and has not been hit since. One time I was in the car driving and git hurt.
    Been years.
    Having said that I’m sure it I’ll get totaled next week but not before I install it’s new battery
  16. Daijoubu
    Daijoubu New Member
    Nice dead bug, if I just want to modify the lamp failure check so it doesn't hyperflash, what would the modification be?
    I have ordered a whole bunch of low values resistors to see if I can get it working with 1.5W bulbs (3W load), if my math is right, I'll need 0.5ohm (target of 2.4W) since the stock shunt is 30miliohms for a 21-28W load (on my flasher)
    I got the CF18 and there's indeed a 1 sec delay before it starts flashing, I got the Novita LM449, while there's no delay with that one, it flashes faster...
  17. Daijoubu
    Daijoubu New Member
    Ah I figured out, so just isolate pin 10 and connect a 250k ohm resistor to +12V, I tried with 220k and 300k, both seems to work fine.
    Found it from this post
    clublexus forums (can't post URL)
    /forums/performance-and-maintenance/950548-possibility-for-rebuilding-or-remaking-92-94-sc300-400-flasher-relay-81980-24020-a-3.html#post10935174
    Dael likes this.
  18. NewHybridOwner
    607
    283
    W. Michigan
    That Web site is now for sale.
