Mods for increased fuel efficiency
Discussion in 'Prius c Accessories and Modifications' started by andrewdenver, Jun 15, 2012.
  1. andrewdenver
    andrewdenver Junior Member
    Denver, Co
    Not sure if this should go here or in the fuel economy forum...
    I've got a Prius C Two and I'm trying to figure out what I can do to increase fuel efficiency. I've been getting about 50-65 mpg to and fro work ( about 20 mi each way ) but I feel like I could get more. Reading though the forums and have come across a few things. I'd really like to get opinions and clarification on a few things. I'm also looking for non-invasive mods, things like changing out light bulbs rather than putting on a body kit.
    I'm currently considering removing the spare tire and jack and keeping a can of fix-a-flat, and for anything that can't fix using 24 hour road side asstance. I'm also planning on making sure my tires are properly ( slightly over ) inflated. What else can I do?
    • Would a plug-in conversion be helpful for a C? Or would the added weight cancel out the gains? Considering this because Colorado still has a tax rebate though 2012.
    • Has anyone blocked their grille with great success? ( I've found some posts about people doing it but no much on *how* to do it, even google seems to have failed me. )
    • Does adding a shark fin reduce drag or is it just for looks?
    • Does an engine block heater only work well in the winter? ( my car is garage kept all year )
    What are some other mods I can easily do that would yield fuel efficiency increase?
    Marcial23 likes this.
  2. F8L
    19,011
    4,081
    50
    Grass Valley, CA.
    In all honesty there is not much to do to the c to improve fuel efficiency. I wouldn't bother removing the spare either. The fuel savings are imperceptible and a can of fix a flat will not fix a blow out.
    1. Keep the car free of extra weight like tools and such.
    2. Keep your tires properly inflated and stick with LRR tires
    3. Use the AC and heater as little as possible to ensure you and the HV battery stay cool. See my post on the subject
    4. Master all of the techniques you need to tackle road situations as efficiently as possible. Join forums like Cleanmpg.com and EcoModder.com.
    The single largest gain to be had is through driving technique. These cars are already so optimized that mods just don't seem to help much.
  3. F8L
    19,011
    4,081
    50
    Grass Valley, CA.
    Damn new software hates my iPad.
    As I was saying, grille blocking is effective when temps drop to 40F and below. Higher than 50F and the gains are lost and you have to be careful with overheating.
    A PHEV conversion is great and can really increase efficiency if your commute can take advantage of the battery power. The drawback is cost. The kits are somexpensive that it doesn't always pencil out.
  4. F8L
    19,011
    4,081
    50
    Grass Valley, CA.
  5. jsfabb
    jsfabb Active Member
    617
    156
    Medford, NY
    Just for reference, I have a Prius HB, but the basic installation should be the same. I kept my grill blocking on until the weather started getting into the 60's.
    What I did was get some pipe insulation from Lowe's ($1) and cut the length as needed to match your front grill. The idea is to mount the pipe insulation by surrounding the horizontal grill piece as if it were a pipe. You will have to cut perpendicular slits to match the vertical grill sections. Just stuff it in. I didn't even use any tie wraps to keep it in place. The first time you fabricate these it should take about 10 minutes. The hardest part is lining up and cutting the vertical slits. After that it literally takes about 1-2 minutes to install and 30 seconds to un-install.
    GOOD LUCK!!!
  6. Marcial23
    Marcial23 New Member
    I did this to my Prius C and made a video about it. I pretty much got really high quality copper wire 6 AWG and installed it on my Prius C making a straight negative connection from the negative battery terminal to the engine AC to AC transformer and engine block, as you know the spark plugs and other sensors are grounded to the engine metal. Usually the battery is conected to the body of the car that is a horrible conductor for electricity. And it has to travel trough all that metal before it gets to the spark plugs and other essential sensors that need grounding. by making a straight connection with a better conductor you increase the responsiveness of the engine over all.
    Increasing fuel efficiency With Grounding Wires In A Prius C - will it break the car?
    iceman13 likes this.
  7. iceman13
    iceman13 Member
    134
    102
    US
    2014 Prius c
    Nice mod but I don’t think this actually increases mpg. I say so because the 12v battery does nothing while the car is already on, unlike a normal car, it just turns on the ECUs, the spark plugs don’t run on that circuit. I could be that your 12v battery is weak and by doing this mod you have effectively made it easier for it to be charged while the car is running and so the inverter isn’t struggling so much to bring it back to good voltage. It is known that an old 12v battery on a Prius will decrease mpg because of this.
    Good mod nonetheless, thanks for sharing.
    iPad ?
  8. bisco
    49,492
    Try the red bullet
  9. Bryce Husserl
    Bryce Husserl Junior Member
    28
    27
    2016 Prius c
    Hey Marcial, I'm technically not an electrical engineer yet, but I'm pretty sure running a ground cable straight from the battery will do almost nothing. Grounding completes the circuit, it just allows the electricity to run through one end (The positive end) to the other (the ground), where then the electrons are generally stripped off into the environment. The battery doesn't have to be grounded to the same thing as the things running off of it and visa versa.
    P.S: I average 58+ MPG on my 2016 C, the best way to increase MPG is to change your driving habits.
