Mods I've done to reduce drag
Discussion in 'Gen 2 Prius Accessories & Modifications' started by 299K, Jan 21, 2020.
  1. 299K
    299K Junior Member
    30
    Cleveland, OH
    Ive removed the front plate to reduce drag.
  2. 299K
    299K Junior Member
    30
    Cleveland, OH
    Ive removed the rear wiper to save weight and aerodynamic drag.
  3. dolj
    dolj Senior Member
    8,559
    4,349
    Wellington, New Zealand
    Have you kept any before and after stats to see if it really has made any difference?
    SFO likes this.
  4. fuzzy1
    10,603
    For more ideas, read up on the AeroCivic.
    TGrracie and ice9 like this.
  5. ice9
    ice9 Active Member
    581
    344
    norfolk va
    2018 Prius
    Nice DIY project.
    He states that Cd (drag coefficient) is well below the 0.25 Cd of a Toyota Prius. I am curious what he estimates his Cd is.
  6. bisco
    52,390
    i took out the passenger seats and other weighty materials. replaced the 12v with a few d cells, and etc.
    i'm up about 5 mpg
    we have front plate requirement, but i'm looking at cone shaped 3d printed frames
    VFerdman and Tim Jones like this.
  7. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    Having to pay a ticket for improper display of plates likely will be a MUCH BIGGER drag.
    Tim Jones likes this.
  8. fuzzy1
    10,603
  9. sam spade 2
    7,035
    2,804
    2017 Prius c
    What are the odds that the whole thread is a joke ?
    I think it is pretty funny........or pretty sad, depending on your perspective.
  10. Vman455
    Vman455 Senior Member
    539
    556
    The Middle
    Removing the front plate won't reduce drag, in fact it is likely doing the opposite. The stock plate holder situates the plate so that it partially covers the cooling air inlet, which reduces the volume of air going through the radiator (drag) and engine bay (more drag). Sending that air around the car body by blocking its path into the radiator reduces drag.
  11. RRxing
    RRxing Senior Member
    2,554
    1,828
    NEPA
    I've lost 25 lbs. so far on my way to my goal weight... :whistle:
    offib likes this.
  12. George W
    George W Senior Member
    911
    514
    San Antonio
    What front plate? Doesn't removing that increase the turbulence around the engine?
  13. VFerdman
    VFerdman Senior Member
    1,194
    1,218
    Western Massachusetts
    I’ve removed the steering wheel, which causes the vehicle to not be driven and a car standing still encounters very little drag.
    jerrymildred and offib like this.
  14. offib
    offib Member
    162
    95
    Dublin
    Four Touring
    Before the winter, I went through an auto-carwash with my '07. The dryer took the aeriel right off, and I haven't gone below 50 mpg.imp since Nov. :giggle:
    VFerdman, jerrymildred and bisco like this.
  15. 299K
    299K Junior Member
    30
    Cleveland, OH
    How many D cells, and nicad or lion or? Thats pretty slick if you can eliminate the 12v battery!
  16. 299K
    299K Junior Member
    30
    Cleveland, OH
    No, it would do no good. Sometimes I drive like an ecomodder, sometimes like fast and furious. I am thinking of removing the radio antenna, and keeping the passenger side mirror folded in. Also thinking about removing the entire interior except for the driver seat.
  17. 299K
    299K Junior Member
    30
    Cleveland, OH
    My state requirement for front plate ends this year. They are only used for revenue generation via speed/red light cams, phuck em.
  18. 299K
    299K Junior Member
    30
    Cleveland, OH
    I have my entire lower intake blocked, only uncover the upper blocks when temps are above 50F.
  19. 299K
    299K Junior Member
    30
    Cleveland, OH
    Congrats! This may be a great motivator for increased mpg. Same as flying small ultralight/recreational aircraft.
  20. 299K
    299K Junior Member
    30
    Cleveland, OH
    Ive driven cars using vice grips where the steering wheel should be.
    VFerdman likes this.
