moisture inside the display
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by dilukperera, Jun 25, 2013.
  1. dilukperera
    dilukperera Junior Member
    Sri Lanka
    please refer the attached picture and its visible, that it has some moisture marks inside the display,
    its is there for long time more than 1 year, ( only on the left side block of the display)
    any idea , how to get rid of it? 20130625_175858.jpg thanks
  2. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,338
    Wilmington, NC
    My dealer had to take the dash apart, remove the lens, clean the lens, and then re-install. I was fortunate that mine was still under warranty at the time.
  3. rrg
    rrg Active Member
    458
    120
    East coast - NJ
    I have seen this happen only once to me.
    There was water/moisture in the car from the humid weather and some wet clothes in a bag left over night in the back of the car.
    Never, ever leave anything inside the car that is wet especially overnight.
    The display for some reason is a magnet to moisture.
    Once I removed everything from the car, I never saw the problem again.
    For example a gym bag left in the car after a work out should be avoided.
    my2cents.
  4. katiesdad7
    katiesdad7 Member
    172
    25
    Stuart, FL
    This was a common problem with earlier cars. Not so much anymore. Easy dealer fix.
  5. JaeYoon
    JaeYoon Junior Member
    korea
    '_'; ....
