Moldy smell
Discussion in 'Gen 2 Prius Main Forum' started by Gravy737, Sep 17, 2017.
  1. Gravy737
    Gravy737 Junior Member
    Charlotte
    My wife has a 2008 Prius with everything minus leather. The car always seems to smell bad. Like water is getting in. Are there any known culprits for interior leaks I can look for? I keep hand testing the carpets after rain but not finding anything. Car has 133k currently.
  2. MelonPrius
    MelonPrius Senior Member
    828
    510
    Las Vegas
    Just curious, because of the recent weather related events. Are you the original owner? If not, did the car come from a state that experienced a bad hurricane or flood after the model year and before you purchased?
  3. Mendel Leisk
    38,875
    Are you using the air conditioning a lot?
    It tends to accumulate water on the "evaporator" (the AC radiator inside the heating/ventilating system, in the dash), similar to a glass of ice water. There's a drain for this water, but it's not perfect, and the evaporator in particular I think, will tend to retain water in it's fins.
    Dark and humid, it's prone to grow mould. There are cleaner kits available from Toyota I believe, and @NutzAboutBolts has a video on how to use it on third gen (pinned in maintenance sub-forum), maybe similar enough in second gen.
    This may or may not be your problem, just one thing to check. If it turns out to be the problem, after cleaning the system, I'd suggest to turn the AC off when your within a mile of your destination, run just the fan to give it time to dry out. It's a pain, but helps. Also just consider using the AC less.
    Raytheeagle likes this.
  4. ETC(SS)
    6,581
    Previous accidents?
    Flood car?
    Pets?
    Cargo?
    Weather Strips?
    It's coming up on fall in Charlotte.
    You might investigate removing the seats and cleaning the carpet. The hatch is also a likely place to look for things like previous water intrusion or itty-bitty pieces of glass from a window replacement.
    +1 on the previous post.
    I've seen one-owner, never wrecked, never flooded, cars owned by non-smokers and non-pet owners smell funky just because the owners never rolled down the window and ran the A/C all the time.
  5. Raytheeagle
    Raytheeagle Senior Member
    11,251
    15,482
    Bay Area, California
    2019 Prius Prime
    Have you checked in the spare tire and 12v battery area?
    With the Gen2's there is a weld seam that fails over time and allows water to accumulate in the rear of the car.
    Keep us posted (y).
    edthefox5 likes this.
  6. IMkenNY
    IMkenNY Im just being nosy
    477
    303
    Tropical Buffalo NY
    Four Touring
    Check the cabin air filter behind the glove box, I have seen some rather interesting build up on these filters over the years.
  7. bisco
    49,694
    some have gotten a bad smell from the hybrid battery vent tubes.
  8. Gravy737
    Charlotte
    Its a NC clean car. Owned for the last 6 years. May look into the ac mold to see if this helps. Spare tire area is clean. Checked the vent tubes from battery. Checked seals on doors. May want to check the drain in front of the windshield. I heard water sloshing around after a carwash. It went away pretty quickly but maybe some is always sitting in there.
  9. edthefox5
    edthefox5 Senior Member
    10,096
    4,808
    Clearwater, Florida
    Like Ray said check in the hatch area again.Take the spare tire out and get a flashlight and look inside the 12 volt battery well for standing water. if you see standing water in the battery well you have a very common cracked body seam up in the hatch area where the quarter panel meets the roof. There's some weld rivets there in the valley of the window hatch that tends to crack. You know the black plastic strips that are on one each side of the roof that go form the back to the front you can just pop that plastic strip off and look in the area where that strip ends in the rear valley for hairline cracks. Water gets n those cracks and runs into the hatch area. pretty common.
    If no standing water in the back hatch area you may just have a funked up e-coil under the dash. Dealer fix for that is to inject microbial cleaning foam back up the drip tube under the car. The foam fills the e-coil and de-funks it. Pretty common with all modern cars. My dealer charges $125 for this service. You can do it yourself but the hardship is jacking the front of the car up high enough to get to the drip tube which basicly comes out under the glove box area. You can buy KOOLIT on Amazon.com its basically the same stuff the dealer uses and has the special rubber attachment t hose to connect to the drip tube.
    If first time this will be cleaned I would get 2 cans.
    The funking happens with intermittent use of the ac. Down here in Florida my ac has been on every single day 365 days a year even in winter for 10 years. The e-coil never gets to dry out. So it never funks up. The best part of that is if you use the ac every single day it usually never fails. Its the intermittent use of ac where its not used for days or weeks that kills a car ac system.
    E-coil cleaning and condenser cleaning and cabin filter replacement is just basic car ac maintenance. I clean my condenser every 2 months.
    10 years later my ac is ice cold. Just like you should do to your home ac system.
  10. ih8spm
    ih8spm Junior Member
    73
    29
    New York
    The Prius from my almost 2 months of ownership is a Intresting car and nothing is as it appears. You are probably getting water in the left rear storage bin area and it may have flowed down to the carpets. The one I bought had such issues and I had to remove and replace the whole carpet and sound dampening material. Take a 10mm socket and extension and remove the drivers side rear storage bin and report back.
    SM-G935P ?
  11. edthefox5
    10,096
    4,808
    Clearwater, Florida
    Where is the drivers side rear storage bin?
  12. ih8spm
    73
    29
    New York
    Open the trunk and to the left there is a triangular shaped cover you lift and under it a bin. In the bottom center of the bin is the 10mm nut.
    SM-G935P ?
  13. ih8spm
    73
    29
    New York
    In the front under the hood by the wipers there's a cover you can remove and clean out all the dirt that accumulates from years if being used in the real world. If thats clogged or full of muck that could cause your odor. Don't forget to check the cabin filter you don't want one like this one I had and if you don't know where it what it is then it's probably time to change it. [​IMG]
    SM-G935P ?
  14. ih8spm
    73
    29
    New York
    Typos....
    SM-G935P ?
  15. ih8spm
    73
    29
    New York
  16. edthefox5
    10,096
    4,808
    Clearwater, Florida
    Oh never seen that mentioned about anything to do with leaking water collection. If that's collecting water
    It's coming from high which is usually the cracked body seam. It's got to have a hell of a leak to get into that bin. Usually just collects under the spare tire and if r ally bad fills that whole Area up and overflows into the back seat carpet,
    You have to be really out if it to let it get that high in the well as it makes a lot of noise sloshing around back there,
    Remove the drain plug under the spare tire and the one in the battery well. Unless you park outside cause Rats will get in real quickl
