Moog Rear Wheel Bearing Assembly
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Pdaddy, Apr 18, 2019.
  1. Pdaddy
    Pdaddy Member
    153
    49
    Should I bite the bullet and pay over 2x for the dealer part? Wondering what model years are compatible for rear wheel bearing assembly and maybe I could look at a junk yard for a later model with fewer miles.
    I have replaced rear bearing assemblies with Moog parts that have gone bad in less that a year. I researched via the chat group to see what might be a reliable part and Moog came up repeatedly, but.... Unfortunately the part only has a 30 day refund through Rock Auto and then they will honor the manufacturer warranty which I have done once. I replaced both sides within 3 months of each other and now the other one is bad. Probably the warranty replacement part will go bad at this rate as well. I will not put another Moog part on my car.
  2. Mendel Leisk
    38,726
    I'm pretty clueless, but I believe there's some other aftermarket bearings that are highly regarded, might even be what Toyota's using, just debadged?
  3. The Critic
    The Critic Resident Critic
    3,193
    2,321
    CA
    NSK, SKF and dealer are the only 3 I will use. Even Timken is now often (but not always) sourced from Asia.
    Pdaddy, m.wynn, Bay Stater and 2 others like this.
  4. Peter123
    Peter123 Active Member
    131
    127
    Have you put the car on a 4 wheel computerized alignment machine to see if something is loading your suspension wrong?
    And have you checked the rear shocks?
  5. Pdaddy
    Pdaddy Member
    153
    49
    With over 200k miles I replaced all shocks and front struts last fall with KYB. I replaced the rear bearing prior to that.
    SM-G920V ?
  6. Pdaddy
    Pdaddy Member
    153
    49
    I dont recall reading about debadged aftermarket bearings when I did my research...if you run across ot please let me know.
    SM-G920V ?
  7. Mendel Leisk
    38,726
    Stick with my first statement. :oops:
  8. Pdaddy
    Pdaddy Member
    153
    49
    Pete recd a few in his post
    SM-G920V ?
  9. Pdaddy
    Pdaddy Member
    153
    49
    It looks like the NSK do not have speed sensor post/connection but the SKF do....
    iPad ?
  10. Mendel Leisk
    38,726
    That would be a deal breaker, I think.
  11. The Critic
    3,193
    2,321
    CA
    NSK:
    OE:
    Looks fine to me?
    Raytheeagle and Mendel Leisk like this.
  12. Mendel Leisk
    38,726
    Wait a sec, what's with that green dot... :ROFLMAO:
  13. The Critic
    3,193
    2,321
    CA
  14. Pdaddy
    Pdaddy Member
    153
    49
  15. The Critic
    3,193
    2,321
    CA
    I see the connector. Do you?
  16. Pdaddy
    Pdaddy Member
    153
    49
    I see now it's the post off the black part. Thanks!
    SM-G960U ?
  17. Pdaddy
    Pdaddy Member
    153
    49
    Are there any seals or lubes that must be applied when the wheel bearing hub is replaced? Anything else I
    I should check with my mechanic about before replacing the hub later this week?
    SM-G960U ?
  18. The Critic
    3,193
    2,321
    CA
    It is a sealed assembly, so no.
    Raytheeagle likes this.
  19. Mendel Leisk
    38,726
    Wouldn't hurt to apply anti-seize to the bore the bearing fits into, and any-and-all faying surfaces? Or some sort of waxy sealant, or wheel bearing grease? Not sure why they would not do that at the factory? I'm assuming they don't, considering the epic battles you read about, extracting the old one.
    Pdaddy and Raytheeagle like this.
  20. Raytheeagle
    Raytheeagle Senior Member
    11,251
    15,482
    Bay Area, California
    2019 Prius Prime
    Epic battles:ROFLMAO::LOL::ROFLMAO::LOL:.
    Very expressive and a vivid image:).
    Hope to not have to work on one to avoid percussive maintenance (y).
