Moonroof fully open causes wind noise
Discussion in 'Prius c Main Forum' started by thearc, Jun 6, 2012.
  1. thearc
    thearc New Member
    33
    Anyone else experience this?
    If I drive at higher speeds (anything above 40mph) I get an unusual wind vibration noise when the roof is fully retracted. If I roll it forward an inch or two it seems fine. Seems like a bit of a design flaw.
  2. akh02
    akh02 New Member
    63
    Oregon
    I noticed that on my drive home from the dealer the first day; had a bit of a panic until I figured out what was going on. If you keep your moonroof at the default "mostly open" instead of trying to open it all the way then it's fine. But all the way open at around 40mph with the windows up and it's like the whole car is vibrating.
  3. dellrio
    dellrio Im pretty much awesome
    281
    88
    37
    Des Moines, IA
    Have you tried cracking the rear windows down just about an inch or so to equalize the pressure and eliminate the wind buffeting?
  4. TC400
    TC400 Active Member
    751
    168
    Pittsburgh, PA
    I realized this too a few days after i bought the car. holy hell the noise it makes just let it go to its default position lol
  5. moezer2112
    moezer2112 Futurist
    115
    50
    Iowa
    akh is correct. When you hit the open button, it will automatically open to the correct position for non-turbulant use. They do offer the option to open it the rest of the way, but at higher speeds you will need some windows open to prevent or minimize the vibration effect. The manual explains this in case anyone hasn't seen that page yet. There's a relatively small spring loaded wind deflector that pops up when the roof opens. I'd rather have the small one that's there than to have a big gaudy one and be able to open the roof all the way. I don't consider it a design flaw, its a design choice within the fields of fluid dynamics and aesthetics.
  6. dellrio
    281
    88
    37
    Des Moines, IA
    Seriously though - crack the rear windows. This is just science, the buffeting effect is caused by a pressure imbalance due to the aerodynamics of this vehicle. Cracking the rear windows solves the problem in most vehicles.
  7. Daze
    Daze Prius C Owner
    92
    23
    Utah
    haha yeah i noticed this too on the drive home from the dealer. I thought it was hilarious! The discovery of a major design flaw within my first few minutes of driving my new car!! But i guess that is why the sunroof automatically stops opening at about 3/4 to keep from making the wind noise.
  8. StarBrite310
    StarBrite310 ~ * ~ * ~ * ~ * ~ * ~
    335
    23
    I noticed this too soon after I got my car and my ears and I freaked out! The noise was truly unbearable. Now if I open the moonroof, I just keep it at the position it "stops" at and don't open it any further.
  9. secondspassed
    secondspassed Member
    112
    26
    Corona, CA
    You guys that are referring to this as a major design flaw... yeah, it's actually just physics. Maybe it's a design flaw that the air in the environment slows down the car, too.
    dellrio likes this.
  10. dellrio
    281
    88
    37
    Des Moines, IA
    ^^^ See this guy gets it!
  11. cmstlist
    cmstlist Member
    183
    40
    Toronto, ON
    Yep it's just physics. Try rolling exactly one window down in any car and driving it at a high speed. Same effect.
Loading...
